MUM Europe 2020
yehia
daily auto reboot
Sat Oct 20, 2018 11:18 pm
is it important to reboot the hotspot router everyday or not ?
abn
Re: daily auto reboot
Sat Oct 20, 2018 11:30 pm
You should add schedule.
See images below
https://drive.google.com/file/d/1MoZVIZ ... p=drivesdk
You can adjust Reboot time and interval time.
yehia
Sat Oct 20, 2018 11:54 pm
See images below
thnx i know about that scheduler ,but am asking for is it important to do this or not
ingdaka
Sun Oct 21, 2018 12:07 am
No it is not important! Even if you have problems with your router or AP, you should fix problem not reboot it everyday!
Ilir Daka
Electronic & Network Engineer
E-mail: ilirdaka@live.com
Mob: +355692982151
WhatsApp: +355692982151
Mikrotik Official Consultant
CCNA | Fortinet NSE3 | MTCRE | MTCSE
yehia
Sun Oct 21, 2018 1:22 am
then why everytime i reboot , the memory of router get back to rise up ?
Jotne
Sun Oct 21, 2018 1:42 am
Do you run latest firmware?
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
yehia
Sun Oct 21, 2018 10:01 am
am running on V42.7
Jotne
Sun Oct 21, 2018 10:10 am
Since its not the latest, you should try 6.42.9 or 6.43.4
I did look at mine RV750Gr3 with 6.43.2 and can see that it has gone from around 18% memory used to 20% memory used in one month.
Since I do block all IP that tries an unknown port for 24 hour, my access list do contain around 1600 IP at any time, so it handles that fine.
MikroTik->Splunk
Users browsing this forum: No registered users and 32 guests
