tonicatel
cant surf on new ip block
Fri Oct 26, 2018 9:41 pm
I recently acquired another block of ip addresses and for some reason I am not able to surf when it gives me the address. Any suggestions?
Kevin
k6ccc
Re: cant surf on new ip block
Sat Oct 27, 2018 1:07 am
For starters, please export and post your configuration so we have some idea what you are doing.
RB750Gr3, RB750r2, CRS326-24G-2S (in SwitchOS), CSS326-24G-2S, CSS106-5G-1S, RB260GS
Not sure if I beat them in submission, or they beat me into submission
Jim
joegoldman
Sat Oct 27, 2018 1:44 am
Are these your own IP's or given to you by the ISP?
IF they are your own, have you started advertising them to upstream providers? Have you notified them of the new range so they can adjust their BGP filters both ingress from you and egress to their providers?
Jotne
Sat Oct 27, 2018 8:19 am
Inside or outside og your router.
If its on inside, you need to change address of the inside interface
old
add address=192.168.88.1/24 interface=Bridge1 network=192.168.88.0
new
add address=192.168.88.1/23 interface=Bridge1 network=192.168.88.0
You may have firewall rules, nat rules, dhcp server, pools and others that need to be change as well.
So post your config.
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
Klose
Fri Nov 02, 2018 12:03 pm
Check your firewall settings. Or use another IP address. lol
Users browsing this forum: No registered users and 30 guests
