MUM Europe 2020
irico
Firewall filter add to address list - decrease timeout
Tue Oct 30, 2018 8:48 pm
I was doing tests with the "add src to address list" option of firewall filter rules and I have seen that the timeout can be increased, but I can not decrease it.
Add to list dynamically IP with timeout 1 minute. Upon receiving a package that meets the requirements, in the TEST list I see how it added with 1 minute timeout..
Then I change the rule so that the timeout is 10 minutes. Upon receiving a package that meets the requirements, in the TEST list I see how it increases to 10 minutes.
Then I change the rule so that the timeout is 10 seconds. Upon receiving a package that meets the requirements, in the TEST list I do not see any timeout changes.
ROS version: 3.43.4
/ip firewall filter add action=add-src-to-address-list address-list=TEST address-list-timeout=1m chain=input dst-port=5000 protocol=tcp
/ip firewall filter add action=add-src-to-address-list address-list=TEST address-list-timeout=10m chain=input dst-port=5000 protocol=tcp
/ip firewall filter add action=add-src-to-address-list address-list=TEST address-list-timeout=10s chain=input dst-port=5000 protocol=tcp
pcunite
Re: Firewall filter add to address list - decrease timeout
Wed Oct 31, 2018 12:32 am
I doubt you can choose anything under the TCP timeout window. 10 Seconds is way to short.
mkx
Wed Oct 31, 2018 10:03 am
The rule adds to the list. If address is in the list already, the entry doesn't get changed. If you want to have different behaviours, you'll have to use more than one address list.
BR,
Metod
xvo
Long time Member
Long time Member
Wed Oct 31, 2018 12:29 pm
It totally makes sense.
When increasing the timeout you are still sure that the action for all previously met rules are still fulfilled.
If you allow to decrease the timeout, that will mean than one rule can cancel the one that was met previously.
irico
Wed Oct 31, 2018 1:35 pm
I am not talking about TCP timeout. I am talking about Address list timeout.
It really is not like that. If an IP is in the list, and goes through a rule that increases the time in that list, it works.
What I really want is to be able to remove an IP from a dynamic list with some "port-knock" type system
WeWiNet
Wed Oct 31, 2018 2:45 pm
A even simpler way is to add the "black listed" IP to a rule just before which "white list" it (accepts it)
It then can still run out in the black list but without any impact!
Can you make that work?
WeWiNet
MTCNA
hapac2, map, hap-lite, ltap-mini, RB4011 :-) !!!
Users browsing this forum: comet48 and 37 guests
