newone
Bridged VLAN - Multiple DHCP-Servers - No response on VLAN-Interface
Fri Nov 02, 2018 10:43 am
Hello!
I would like to create separate where each vlan has its own dhcp server. If I connect my client to the router on eht6 and set the ip address manually I can ping the router. However, if I would like to receive the ip from the dhcp-server no address is assigned.
I have tested to assign one dhcp-server to bridge1. With this config the client immediately has an IP address.
Do you have any ideas where the issue could be located?
Below you can find my current config file.
Thank you very much!
# model = CCR1009-7G-1C-1S+
add name=bridge1
/interface vlan
add interface=bridge1 name=100-mgmt vlan-id=100
add interface=bridge1 name=401-hp23-public vlan-id=401
add bridge=bridge1 hw=no interface=ether3
add bridge=bridge1 hw=no interface=ether4
add bridge=bridge1 hw=no interface=ether5 pvid=401
add bridge=bridge1 hw=no interface=ether7
add bridge=bridge1 hw=no interface=sfp-sfpplus1
add bridge=bridge1 hw=no interface=combo1
add bridge=bridge1 interface=ether6 pvid=100
/interface bridge vlan
add bridge=bridge1 tagged=sfp-sfpplus1 untagged=ether6 vlan-ids=100
add bridge=bridge1 tagged=sfp-sfpplus1 untagged=ether5 vlan-ids=401
add name=dhcp-100-mgmt ranges=192.168.0.100-192.168.0.250
add name=dhcp-401-wlan-public ranges=172.16.1.10-172.16.1.250
add name=dhcp-402-wlan-private ranges=172.16.2.10-172.16.2.250
add address-pool=dhcp-100-mgmt disabled=no interface=100-mgmt name=100-mgmt
add address-pool=dhcp-401-wlan-public disabled=no interface=401-wlan-public name=401-wlan-public
add address=192.168.0.1/24 comment=defconf interface=sfp-sfpplus1 network=192.168.0.0
add address=192.168.0.1/24 interface=100-mgmt network=192.168.0.0
add address=172.16.1.1/24 interface=401-wlan-public network=172.16.1.0
add address=172.16.1.0/24 dns-server=172.16.1.1 gateway=172.16.1.1 netmask=24
add address=192.168.0.0/24 dns-server=192.168.0.1 gateway=192.168.0.1
xvo
Long time Member
Long time Member
Re: Bridged VLAN - Multiple DHCP-Servers - No response on VLAN-Interface
Fri Nov 02, 2018 12:09 pm
You need to add bridge itself as a tagged port for your vlans, to make a connection to ip configuration of vlan-interfaces:
add bridge=bridge1 tagged=bridge1,sfp-sfpplus1 untagged=ether6 vlan-ids=100
add bridge=bridge1 tagged=bridge1,sfp-sfpplus1 untagged=ether5 vlan-ids=401
anav
Sun Nov 04, 2018 12:55 am
Psssshaw, this is so basic and easy, piece of cake but of course I will let xvo handle it. He needs the practice........... ;-PPPPPPPP
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
anav
Sun Nov 04, 2018 12:57 am
Just kidding, inside joke with xvo, he has helped through the same process held my hand, heck practically changed my diapers LOL. You are in good hands, but plug your nose, dont like his aftershave (who am I kidding I'm convinced he doesn't know what a razor looks like must be his perfume errr cologne).
xvo
Long time Member
Long time Member
Sun Nov 04, 2018 1:40 am
I guess that's how euphoria from making vlan setup to finally work for the first time looks like from aside ;)
anav
Sun Nov 04, 2018 7:45 pm
Hahah, true dat. By the way, if you put on glasses and ditch the hat and drive by in a red car, one might you are NORMIS LOL, heee heee haaa haaa.
newone
Wed Jan 02, 2019 12:42 pm
Hello!
Thank you for your help! With the changed config dhcp is working perfectly for all clients connected to a switch which is connected via tagged port. However, if I try to connect a client directly to ether5 or ether6 this client does not receive an IP from the DHCP.
Here is the config:
Code: Select all
# jan/02/2019 11:24:08 by RouterOS 6.43.4
# software id = IDHP-Y9BI
add name=bridge1
set [ find default-name=ether1 ] speed=100Mbps
set [ find default-name=ether2 ] speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full speed=100Mbps
set [ find default-name=ether6 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full speed=100Mbps
set [ find default-name=ether7 ] speed=100Mbps
set [ find default-name=sfp-sfpplus1 ] advertise=10M-full,100M-full,1000M-full
/interface vlan
add interface=bridge1 name=120-print vlan-id=120
add interface=bridge1 name=401-public vlan-id=401
add name=dhcp-100-mgmt ranges=192.168.100.100-192.168.100.250
add name=dhcp-401-public ranges=172.16.1.10-172.16.1.250
add name=dhcp-402-23-private ranges=172.16.2.10-172.16.2.250
add name=dhcp-120-printer ranges=192.168.20.100-192.168.20.250
add address-pool=dhcp-401-public disabled=no interface=401-public name=401-public
add address-pool=dhcp-120-printer disabled=no interface=120-print name=120-print
add bridge=bridge1 hw=no interface=ether6 pvid=100
add bridge=bridge1 tagged=sfp-sfpplus1,bridge1 untagged=ether6 vlan-ids=100
add bridge=bridge1 tagged=sfp-sfpplus1,bridge1 untagged=ether5 vlan-ids=401
add bridge=bridge1 tagged=sfp-sfpplus1,bridge1 vlan-ids=120
add address=192.168.100.1/24 interface=100-mgmt network=192.168.100.0
add address=10.0.1.1/24 network=10.0.1.0
add address=172.16.1.1/24 interface=401-public network=172.16.1.0
add address=192.168.20.1/24 interface=120-print network=192.168.20.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
add address=192.168.100.0/24 dns-server=192.168.100.1 gateway=192.168.100.1 netmask=24
add address=192.168.20.0/24 dns-server=192.168.20.1 gateway=192.168.20.1
mkx
Wed Jan 02, 2019 1:14 pm
Set vlan-filtering=yes on bridge1 in /interface bridge. Setting bridge MAC address by hand might proove benefitial (for other reasons) as well.
BR,
Metod
Users browsing this forum: adenghamdi, Here4U, Hero and 62 guests
