moheyelbaz
Forwarding Avaya via VPN
Wed Nov 14, 2018 9:07 am
I have 2 router mikrotik.
First: VPN 10.10.10.1 (172.16.10.0/24 Local)
Second: VPN 10.10.10.102 (172.16.12.0/24 Local)
the avaya PBX is locally into 172.16.10.201
the phone is ringing but no sound
i tried to check the connection
the connection is going to avaya but when comes out the destination ip chenged to be local
i tried to make dst-nat but no way.
VipITBE
Re: Forwarding Avaya via VPN
Fri Dec 07, 2018 12:55 pm
make sure that you don't NAT over the VPN tunnel.
no sound or one-way-audio typically also means that the audio is hitting a firewall rule, check those as well
msatter
Fri Dec 07, 2018 1:54 pm
How do I route to VPN without NAT?
I only find example with NAT and my im thoughts are that I need the normal entry in IP-Route to the VPN and tag/point in Mangle to the route of theVPN.
Till now I always needed a SRC-NAT to gateway of the VPN.
One RB4011 (cooled) and a RB760iGS (hEX S) in series. The 4011 Does PPPoE/IKEv2.
The cooler: viewtopic.php?f=3&t=138613&start=300#p799879
Running:
RouterOS 6.47 / Winbox 3.24 / MikroTik APP 1.3.14
Users browsing this forum: Bing [Bot] and 39 guests
