arash88
Share Internet over SXTs
Sat Nov 17, 2018 1:07 pm
Hi everyone,
I have a ptp link with two SXT's configured as same as this Topic with same scenario and same settings. (Though AP1 and AP2 are not mikrotiks).
Ok Now I have Internet on my AP1 but i can't get internet through AP2. What should i do? Currently i have connected these two sub-nets and two network can ping each other but no internet so far.
Thanks in advance guys.
plisken
Re: Share Internet over SXTs
Sun Nov 18, 2018 8:35 pm
Try this configuration to obtain a stable point to point link.
Spoken in Dutch but just follow my tutorial
https://www.youtube.com/watch?v=FAGbPd0Nm94&t=9s
Goodluck
arash88
Sun Nov 18, 2018 11:48 pm
Goodluck
Thanks alot @plisken for your nice tutorial but as i said my users are on AP1 and AP2 (two subnets), what should i set for routes in AP1 and AP2? Shouldn't I set IP Addresses on both ether1 ports of SXTs and route them through APs?
Thanks a lot for your time and knowledge
plisken
Mon Nov 19, 2018 9:10 am
Maybe you can configure VLAN on the SXTs
But for that I would like to see your complete configuration on a drawing
arash88
Wed Nov 21, 2018 11:22 am
Hi @plisken
As i said my settings are the same as this topic and this is my drawing of network. I already have my link running without MPLS, but no internet on AP2. All my users are on two APs.
plisken
Wed Nov 21, 2018 12:27 pm
Hello, do you plug the sxt on the WAN site of your TP-link router?
arash88
Wed Nov 21, 2018 2:43 pm
WAN port on AP1 is connected to internet with pptp so SXT1 is connected to lan switch of AP1.
In AP2 when i connect sxt2 to WAN port i get Internet and AP1 network, but also i get 2 problems: 1- AP1 can't see AP2 network anymore 2- Can't discover sxt's and connect to them from AP2 anymore. 3- connection from AP2 to AP1 gets more sloppy with few drops.
So can i get internet on AP2 with both SXT's connected to AP's lan switch?
Thanks alot.
plisken
Wed Nov 21, 2018 5:42 pm
Hello, that you can not see the SXTs anymore is very normal.
On the WAN port of your TP link there is an active firewall that blocks this traffic.
Can you put the TP link in AP mode only?
Instead of the tp-link you can place a switch and there you connect the tplink in ap mode only.
arash88
Wed Nov 21, 2018 8:06 pm
Hey plisken, can you explain more what you mean? should i only set my AP2 on AP-only?
plisken
Wed Nov 21, 2018 9:06 pm
Yes, and use a switch to connect SXT2 and the TP-link in AP mode.
arash88
Thu Nov 29, 2018 8:29 pm
Hey @plisken , Thanks alot for helping.
By saying put AP2 in AP mode and use switch you mean i remove my subnet2? because i can't do that. if you mean anything else can you draw me something?
As i said before currently i have a bridge-station bridge link and i don't have any tunnel, should i still go for mpls/vpls? does it help interoperability of my current network?
Thanks.
arash88
Sun Dec 02, 2018 11:39 am
Anyone have any idea for me?
mkx
Sun Dec 02, 2018 12:05 pm
Can you post configuration of both SXTs?
BR,
Metod
plisken
Sun Dec 02, 2018 3:04 pm
Can you make a drawing of your configuration?
Then I can see how to configure the SXTs
mkx
Sun Dec 02, 2018 3:22 pm
OP linked same config in post #5.
BR,
Metod
arash88
Sun Dec 02, 2018 10:23 pm
Hi dear @mkx and @plisken
Thank you guys so much for showing interest in my problem. As i said i did the exact same as this topic and this is my drawing of my whole network. I have a good link but no internet in AP2. When i put the sxt2's ether1 to AP2's WAN port, i get internet but AP1 loose contact to AP2 network and interoperability is gone now i suppose.
Again thanks guys
plisken
Mon Dec 03, 2018 9:27 am
Login into the SXT1 and in new terminal type "export" and paste the result on this forum.
Remove passwords.
Do the same on SXT 2
I test this configuration and try to help you.
plisken
Mon Dec 03, 2018 1:26 pm
I have hopefully a solution for you. caution this is made with a 5 GHz; SXT G-5HPacD
SXT1
add fast-forward=no name=bridge-local
add fast-forward=no name=bridge-sxt2
/interface wireless
set [ find default-name=wlan1 ] disabled=no frequency=5200 mode=ap-bridge ssid=sxt2
add bridge=bridge-local interface=ether1
add bridge=bridge-local interface=wlan1
add address=10.0.0.1/30 interface=wlan1 network=10.0.0.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=bridge-local
/system clock
set time-zone-name=Europe/Brussels
/system identity
set name=SXT1
/system routerboard settings
set silent-boot=no
SXT2
/interface wireless
set [ find default-name=wlan1 ] disabled=no frequency=5200 mode=station-bridge ssid=sxt2
add name=dhcp_pool0 ranges=192.168.1.1-192.168.1.200,192.168.1.202-192.168.1.254
add address-pool=dhcp_pool0 disabled=no interface=ether1 name=dhcp1
add address=10.0.0.2/30 interface=wlan1 network=10.0.0.0
add address=192.168.1.201/24 interface=ether1 network=192.168.1.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=wlan1
add address=192.168.1.0/24 dns-server=1.1.1.1,8.8.8.8 gateway=192.168.1.201
add action=masquerade chain=srcnat out-interface=wlan1 src-address=192.168.1.0/24
/system clock
/system identity
set name=SXT2
set silent-boot=no
Attention, pay attention to the local settings and the frequency. This is configured on a 5 GHz device
I hope to have helped you.
The TP-Links must be set as AP only.
Can I use your plan on my website please?
arash88
Tue Dec 04, 2018 6:23 pm
SXT1
/interface wireless
/ip dhcp-client
/system clock
/system identity
set name=SXT1
set silent-boot=no
SXT2
/interface wireless
/ip dhcp-client
/system clock
/system identity
set name=SXT2
set silent-boot=no
Thank you dear @plisken so much i will try these settings and hit you back tomorrow. You may use anything you want. Can you give me your sites link?
Off topic: Does MPLS/VPLS link gives me better interoperability or anything better at all?
Again thank you so much.
plisken
Tue Dec 04, 2018 11:14 pm
Hello, your welcome no problem.
My website link is https://www.wirelessinfo.be.
I'm curious and hope it's this configuration that you need.
The TP-Links must now be configured in AP mode.
MPLS / VPLS is faster but makes it more complicated.
So I do not know if you would benefit from it.
Greetings and have a nice day
Goodluck
Users browsing this forum: No registered users and 9 guests
