shady79
Different speeds to the same router.
Wed Nov 28, 2018 11:10 am
Hi
There are 2 mikrotik routers connected between over isp fiber 1Gbit/s link. I launched the eoip tunnel on them. On both side I create bridge interface without any phisical interfaces added to it only for tunnel connection. If I test bandwidth speed from one to another to bridge ip I get result:
when I do the same but to IP on local interface
Why those results are so different?
MTCNA 1811NA3965
2frogs
Long time Member
Long time Member
Re: Different speeds to the same router.
Thu Nov 29, 2018 7:28 am
CPU usage is most likely the cause as it only uses a single core. This bandwidth tool should not be used as an accurate measure.
shady79
Thu Nov 29, 2018 8:22 am
at 950Mbit/s
at 75Mbit/s
Ii is not a cpu problem. Take me a while, I will draw how it is connected.
MTCNA 1811NA3965
shady79
Thu Nov 29, 2018 11:24 am
speed from CCR1016 to IP 192.168.123.5 is full to IP 192.168.2.1 is only 76Mbit/s
Also copying files from one PC behind router A to another PC behind router B is very slow.
Here is a draft:
WodaLan.pdf
MTCNA 1811NA3965
Users browsing this forum: MSN [Bot] and 14 guests
