eduncan911
New to SPF+: Direct Connect questions
Fri Nov 30, 2018 8:39 pm
Hello, first time poster.
The CRS328-24P-4S+RM has 4x "SPF+" ports. The new-but-not-released CRS312-4C-8XG has 4x "SPF+" combo ports as well.
Can I use some type of "Direct Connect" cable between these two switches for the 10G SPF+ connections? Being new to fiber, I am unsure of the terminology or if this how they are intended to connect.
What I can find is that Mikrotik has a "SFP+ 3m direct attach cable" as well (3m being way too long for my needs). Can I just purchase 1 of these cables and simply plug them in between the switches for 10G links? Is it really that easy - and cheap?
https://mikrotik.com/product/SplusDA0003
Curious, could I connect 2, 3 or even all 4 between these two switches - and use LAG for 40 Gbps between the two switches? :)
I am trying to avoid those expensive adapters, and just want to connect a single inexpensive SPF+ cable between these two devices with a simple cable in a rack sitting on top of each other.
Bergante
Re: New to SPF+: Direct Connect questions  [SOLVED]
Sat Dec 01, 2018 4:27 pm
Should be as simple as that unless some odd compatibility problem arises.
Those so called DA (direct attach) cables are well known standards. And they are a great solution because the passive ones consume really a tiny amount of power. They just contain a tiny microcontroller to identify themselves (Hi, I am a passive DA cable supporting 10 Gbps, etc) and some passive impedance matching stuff.
The cable is actually twinaxial cable, not fiber.
eduncan911
Sat Dec 01, 2018 5:29 pm
Excellent. Thank you!
So, that would mean these actual "expensive" adapters are the fiber optic versions? Ah, I see now why they would be expensive - converting a digital signal to light, and back again.
And I take it that means there is a limited length you can do with DA/DC due to the twinaxial copper, vs light over long distances. Also, I've heard of lower latency with fiber - so that would make sense as well. In my homelab, latency of gigabit either over RJ45 copper is a non-issue. So yeah, non-fiber works for me with the DC/DA cables.
Am I assuming everything correctly?
Last question: What's typically the max length for these DA/DC cables? I'm curious now of a run about 50 to 80 feet long from the garage rack to my office.
Thanks again!
mkx
Sun Dec 02, 2018 11:48 am
Typical use for DA cables is interconnection within same cabinet, so they usually come in lengths of a feet or three. For connection with length of 50 to 100 feet fibre is preferred solution (although 10Gbps over UTP cat6/7 or even 5e would work as well over this distance ... fibre might actually be more cost efficient than copper).
BR,
Metod
Users browsing this forum: No registered users and 12 guests
