orbee
Netinstall not install routeros
Mon Dec 03, 2018 5:04 am
Hi
So after saw I can't login to my router cause winbox said wrong username and password I try to reset the router. Issue is when I try to install the routeros on the router the installation bar on netinstall stay on transferring then disappear and nothing happen.
What can I do?
Steveocee
Re: Netinstall not install routeros
Mon Dec 03, 2018 5:39 pm
Try having console open and watch what it says to do. I had similar and the router was waiting for a reboot.
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
AminYounessi
Trainer
Trainer
Wed Dec 05, 2018 7:37 am
No problem browse for another roueros on your netinstall, for example try older routeros version and after transferring done(you see the installation box getting blue) then use to netinstall, winbox or any other things that you want to upgrade to the latest version of winbox.
Or simply download the latest version of netinstall.
Best Regards
WeWiNet
Fri Dec 07, 2018 4:54 pm
Have you tried to just reset router: power down, power up with reset button pressed until LED blinks (roughly 5 seconds) and then release button?
Then user admin and no password will be set
WeWiNet
MTCNA
hapac2, map, hap-lite, ltap-mini, RB4011 :-) !!!
Users browsing this forum: No registered users and 29 guests
