neshafee
SSH login
Tue Dec 04, 2018 3:40 pm
How to define ssh version in Mikrotik
sebastia
Re: SSH login
Tue Dec 04, 2018 8:50 pm
Not sure what you mean? The ssh server version mikrotik uses is v2.
anav
Re: SSH login
Tue Dec 04, 2018 9:33 pm
Do you mean this...........
More Secure SSH access
RouterOS utilises stronger crypto for SSH, most newer programs use it, to turn on SSH strong crypto:
/ip ssh set strong-crypto=yes
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
neshafee
Re: SSH login
Wed Dec 05, 2018 8:56 am
Ok fine. Thanks for your reply. So how can I find out the SSH version.
normis
Re: SSH login
Wed Dec 05, 2018 12:03 pm
what version?
baragoon
Re: SSH login
Wed Dec 05, 2018 12:10 pm
Already answered, Protocol version is 2
vmunix ~ $ telnet hex 22
Trying 1xx.xx.xx.xx...
Connected to hex.
Escape character is '^]'.
SSH-2.0-ROSSSH
telnet> Connection closed.
normis
Re: SSH login
Wed Dec 05, 2018 12:19 pm
No, this is RouterOS insternal app version :-D
What do you want to know specifically ?
Users browsing this forum: No registered users and 28 guests
