49er
Brute Forse SSH blacklist
Fri Dec 21, 2018 8:24 am
Hi.
I have a bruteforce blacklist in my device but I want to exclude 1 IP address, is that possible?
I Like to exclude 1 (or more IP address to be put on the blacklist address-list)
/ip firewall filtter
add chain=input protocol=tcp dst-port=22 src-address-list=ssh_blacklist action=drop \
comment="drop ssh brute forcers" disabled=no
add chain=input protocol=tcp dst-port=22 connection-state=new \
src-address-list=ssh_stage3 action=add-src-to-address-list address-list=ssh_blacklist \
address-list-timeout=10d comment="" disabled=no
src-address-list=ssh_stage2 action=add-src-to-address-list address-list=ssh_stage3 \
address-list-timeout=1m comment="" disabled=no
add chain=input protocol=tcp dst-port=22 connection-state=new src-address-list=ssh_stage1 \
action=add-src-to-address-list address-list=ssh_stage2 address-list-timeout=1m comment="" disabled=no
add chain=input protocol=tcp dst-port=22 connection-state=new action=add-src-to-address-list \
address-list=ssh_stage1 address-list-timeout=1m comment="" disabled=no
mkx
Re: Brute Forse SSH blacklist
Fri Dec 21, 2018 8:36 am
It would be easier if you constructed a whitelist and accept connections from whitelisted src addresses before you deal with brute forcers.
BR,
Metod
49er
Fri Dec 21, 2018 12:06 pm
I know but I want to be able to access from anywhere and that is not possible if you use whitelist.
mkx
Fri Dec 21, 2018 1:20 pm
You wrote in OP that you wanted to "exclude 1 IP address" from the black list. Can you make up your mind?
Actually you can connect from anywhere ... as long as used IP address is not blacklisted already.
BR,
Metod
2frogs
Long time Member
Long time Member
Fri Dec 21, 2018 1:29 pm
Actually, Port Knocking allows for this.
https://wiki.mikrotik.com/wiki/Port_Knocking
But, the short answer is to add an accept for an Source IP before your brute force. Or edit brute force to include !Source IP.
Jotne
Fri Dec 21, 2018 3:01 pm
For SSH I do the following.
1. Port Knocking
2. Use another port than 22
3. If some one tries a none open port on my system, the get blocked on all port for 24 hour..
PS I do not have SSH to my Router, but to a server. From that I can SSH to the Router.
The server is logged in many ways so I sees whats going on.
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
Users browsing this forum: No registered users and 32 guests
