Hi all,
I'm new in the communicty and try to configure a very basic VLAN setup on my CRS125. It would be nice if you could explain me following problem.
I just want to have two ports of the switch configured to vlan30 as untagged (access port).
The CRS is running RouterOS v6.43.4 and from the documentation I thought that the master port config is not required anymore.
Config looks like this:
add ports=ether22,ether24 vlan-id=30
/interface ethernet switch ingress-vlan-translation
add customer-vid=0 new-customer-vid=30 ports=ether22,ether24
This setup is not working unless I confugre any port with that VLAN as tagged.
I configured lots of Cisco devices in my life and there you need to create a l2 vlan and then add it to the ports.
Can somebody explain me in detail why the communication is not working for the setup without tagged port?
Thanks in advance.
