e76aa
Voice vlan and mikrotik
Sun Dec 30, 2018 11:05 pm
How to create voice VLAN on Mikrotik? I create as normal VLAN and I add DHCP server but when I plug telephone doesn't receive an IP address. On switch it show that I plug telephone as tagged port. Switch is PLANET gs-4210-24p4c Mikrotik CRS212-1G-10S-1SplusIN and IP telephony is Grandstream.
mducharme
Trainer
Trainer
Re: Voice vlan and mikrotik
Sun Dec 30, 2018 11:15 pm
You should enable DHCP VLAN on your phone: https://www.grandstream.com/sites/defau ... _Guide.pdf
Or configure the VLAN manually. MikroTik does not currently support LLDP-MED which is necessary for communicating voice VLAN ID to phones. This normally isn't a huge problem since most phones support being given the VLAN ID via DHCP option.
markdutton
Thu Mar 14, 2019 2:09 pm
Yeah sorry. Beg to differ. LLDP is essential for VOIP deployments. Any smart, or higher switch that can't do this is just a toy.
mozerd
Thu Mar 14, 2019 3:24 pm
LLDP
I deploy lots of dedicated VLAN's for voip and have zero issues. But I have not used any Grandstream products so I do not have any clue how Granstream works. Most of my voip Phones are either Pollycom or Ubiquiti or Gigaset or Yealink.or SNOM
But I do know that LLDP-MED is not currently supported by MikroTik ... perhaps that will come later. .... certainly has not been an issue for me and my deployments.
Users browsing this forum: No registered users and 53 guests
