tomvviss
Best VPN solution for Mikrotik LTE clients
Tue Jan 08, 2019 10:36 am
I am looking for the best VPN solution to connect RB912R-2nD-LTm&R11e-LTE clients installed in vehicles to our network. Because of a variable quality of LTE signal (sometimes even EDGE) I need as stable and quick connection as possible.
My intension was to use OpenVPN via UDP, but due to lack of UDP support in Mikrotik I ended up with OpenVPN via TCP. OpenVPN server is running on FreeBSD, however I would like to build a new VPN server on Mikrotik CHR.
Server has static public address, clients have dynamic private addresses from a mobile provider. I am sending video from IP cameras from vehicle to a central video server, however with a very limited bandwidth – let say 20kbit/s.
What VPN solution would you recommend?
Thanks for any advice.
Tom
AndresRqta
Re: Best VPN solution for Mikrotik LTE clients
Thu Jan 10, 2019 8:18 pm
I'm using Openvpn over Mikrotik/TCP from various years ago - in Argentina, in some small towns with mobile connections+ GPRS / EDGE and it really keeps the connection.
Regards!
vic3apex
Tue Apr 02, 2019 10:02 am
The case of this device does not look like waterproof. Are there any experiences of using this device outside?
Users browsing this forum: BFritz, durkonos, fposavec, jirinovak, jvanhambelgium, webparent and 69 guests
