augi
Can't access OmniTik
Wed Jan 09, 2019 4:29 pm
I have 2 OmniTIk routers.
One of them I can access easily using winbox and both MAC address and IP address.
The second one, during configuration, has set 0.0.0.0 IP address. And I can't access routerOS now.
I looked for solution of this problem in many topics on forum. What I tryed to do:
- disable all network interfaces (besides LAN used to connect OmniTik),
- plug the device into a working Mikrotik router and under IP->Neighbors try to run MAC-Telnet. After entering login and password telnet displays: "disconnected".
- use the application NeighbourViewer.exe - the result was similar as mentioned above.
- reset button is broken, i don't now why.
Do you have any idea how to solve this problem? Is this router broken down?
Guntis
Re: Can't access OmniTik
Thu Jan 10, 2019 11:55 am
If you are trying to connect to first port your connection might fail due to default-configuration. Try to connect to it using different port.
Be sure that, when you try to reset the device, you start pressing the reset button before applying power.
https://wiki.mikrotik.com/wiki/Manual:R ... tton_reset
augi
Thu Jan 10, 2019 1:30 pm
I know that in default configuration it is not allowed to get access by port 1 (as I mentioned above I have the other one Omnitik and I can access it without any problems).
As I wrote, I'm not able to reset device because reset button is broken down.
Any other ideas?
Users browsing this forum: jakub7, NoahDarby and 51 guests
