roe1974
"bridge" one device from one subnet to other subnet (OVPN)
Mon Feb 11, 2019 11:47 am
i have a home router (192.168.0.0/24) and a router in the underground garage (192.168.2.0/24)
Both connected through OVPN site-to-site Layer 3
Is it possible,to "bridge" one device from garage to home ... so that this device is in the same IP Range ?
Richard
sebastia
Re: "bridge" one device from one subnet to other subnet (OVPN)
Mon Feb 11, 2019 1:05 pm
Yes, with eoip tunnel (which can be secured by ipsec). you'll need to put the eoip interface in local bridge at both ends.
anav
Mon Feb 11, 2019 2:23 pm
From what I understand you use one physical port on both routers and one of them is configured to be on the LAN of the other one (whichever option you want to use).
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
Users browsing this forum: No registered users and 19 guests
