MUM Europe 2020
TheSirStumfy
Setting up incoming traffic
Fri Feb 15, 2019 4:28 pm
Ok this will be a super noob question, but im having problems setting up a VPN.
The setup didnt work, so i tried to just ping my static IP and i get no response even there. I also have no idea what is cutting it off?
Ping works if i am connected to the router (to public ip) but from outside (lets say from LTE) nothing...
What must i do to let traffic in?
Setup is a bog-standard defconf.
anav
Re: Setting up incoming traffic
Fri Feb 15, 2019 4:36 pm
post config please
/export hide-sensitive file=yourconfig
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
sebastia
Fri Feb 15, 2019 4:39 pm
Do you get a public ip? Or maybe private or CGNat specific one?
TheSirStumfy
Fri Feb 15, 2019 4:43 pm
Its a static public IP form ISP. internet on the router works fine, but pinging it form outside seems impossible
TheSirStumfy
Fri Feb 15, 2019 4:46 pm
Config removed for safety
anav
Fri Feb 15, 2019 5:05 pm
/ip dns static
add address=192.168.88.1 name=router.lan
You can get rid of this default rule as your setup changes covers DNS.
established,related,untracked
You can remove untracked as its a special case not typically used.
Same here you can remove untracked.
Other than that I dont see anything out of whack that would cause issues???
Can you confirm with grc.com that your router is not pingable.
TheSirStumfy
Fri Feb 15, 2019 5:17 pm
tried all of suggested stuff, nothing. still no ping from outside.
DummyPLUG
Fri Feb 15, 2019 5:28 pm
First of all make sure ping isn't filter by your ISP, as I can't see your firewall config so I can't comment on that.
and you said VPN isn't working, is that a PPTP or IPSec or OVPN?
TheSirStumfy
Fri Feb 15, 2019 5:42 pm
Called ISP, there fault, incorrect gateway settings on there modem.
Facepalm
TheSirStumfy
Re: Setting up incoming traffic  [SOLVED]
Fri Feb 15, 2019 7:14 pm
Regarding VPN i had to DMZ the main router on the modem/router to get trough, in case anyone in future helps.
DummyPLUG
Fri Feb 15, 2019 7:18 pm
You mean there is another router (provide by ISP?) before the mikrotik? If so see if that router can set to "bridge mode"
sometime DMZ won't solve double nat problem
TheSirStumfy
Fri Feb 15, 2019 7:21 pm
Yeah in front there is the standard modem/switch/wifi thing the ISP gives you, since they dont allow PPPOE direct on the Microtik.
TheSirStumfy
Fri Feb 15, 2019 7:25 pm
Its seems this DMZ actually does what it says :)
DummyPLUG
Fri Feb 15, 2019 7:29 pm
Try google for solutions, may be somebody had figure a way to use bridge mode for that modem or find a way to use their own router to do pppoe
DummyPLUG
Fri Feb 15, 2019 7:30 pm
Most of the time, but not everything works right for double nat even after DMZ
Users browsing this forum: MSN [Bot] and 41 guests
