ignasand
wyze cam port forwarding
Mon Feb 18, 2019 10:15 am
first of all I am not a CS specialist, so sorry for my unclear descriptions.
I have RB951G-2HnD, OS v6.43.8. I am having trouble connecting cloud camera Wyze Cam V2.
I have found that UDP and TCP ports need to be open (as I understand OPEN == FORWARDING).
One source claim that "UDP: open all ports
TCP: Open port 22, 80, 8000, 443, 21047, 10001
Onother: "You do need to have ports open! Here are the ports required for optimal use: TCP: 80, 123, 443, 8000, 8605, 10001, 10002, and 22345. UDP: 80 and 443"
I tried to open those ports, but did not succeded.
Camera gets it's local ip adress (192.168.88.** checked via winbox) but could not connect to internet (blinking led on camera indicate that there is no connection)
I was wondering maybe I can remove some firewall or NAT filter rule? Or quickly open all ports with simple command?
Firewall filters:
[admin@MikroTik] > /ip firewall filter print
 0  D ;;; special dummy rule to show fasttrack counters
      chain=forward action=passthrough
 1    ;;; defconf: accept established,related,untracked
      chain=input action=accept connection-state=established,related,untracked
 2    ;;; defconf: drop invalid
      chain=input action=drop connection-state=invalid
 3    ;;; defconf: accept ICMP
      chain=input action=accept protocol=icmp
 4    ;;; defconf: drop all not coming from LAN
      chain=input action=drop in-interface-list=!LAN
 5    ;;; defconf: accept in ipsec policy
      chain=forward action=accept ipsec-policy=in,ipsec
 6    ;;; defconf: accept out ipsec policy
      chain=forward action=accept ipsec-policy=out,ipsec
 7    ;;; defconf: fasttrack
      chain=forward action=fasttrack-connection connection-state=established,related
 8    ;;; defconf: accept established,related, untracked
      chain=forward action=accept connection-state=established,related,untracked
 9    ;;; defconf: drop invalid
[admin@MikroTik] >
All kind of advices are welcome.
Thank you for your time,
Ignas
ignasand
Re: wyze cam port forwarding
Fri Apr 19, 2019 9:56 am
Quick note:
if I disable default NAT rule masquerade (when camera tries to connect to wifi) and enable it after few seconds, everything works fine.
anav
Fri Apr 19, 2019 5:30 pm
My recommendation is to get rid of any modern device that depends upon you open up your router to the world of insecurity.
Nothing I read with any validity suggests you need any port forwarding.
The issue is most likely your config. Please post.
/export hide-sensitive file=yourconfig
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
k6ccc
Fri Apr 19, 2019 6:44 pm
I can absolutely assure you that the Wyze cameras do NOT require anything "special" to be opened on a reasonably normal router configuration. As long as a LAN device can get to the internet and responses get back to it, it will connect just fine.
I have 13 Wyze cameras (2 Pans and 11 V2). Other than putting them on their own LAN and WiFi, I did nothing abnormal (I don't entirely trust Chinese camera inside my firewall).
RB750Gr3, RB750r2, CRS326-24G-2S (in SwitchOS), CSS326-24G-2S, CSS106-5G-1S, RB260GS
Not sure if I beat them in submission, or they beat me into submission
Jim
anav
Fri Apr 19, 2019 9:37 pm
@K6ccc, the only reason your cloud video is filtered through the chinese army servers is to ensure that all your house porn is stored safely. ;-)
ignasand
Sun Apr 21, 2019 9:31 am
Thank you for reply.
Here is my config script
# apr/21/2019 09:22:47 by RouterOS 6.43.8
# software id = XRIV-K778
# model = 951G-2HnD
# serial number = 557E0451F7D0
add admin-mac=4C:5E:0C:E0:B5:E7 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=\
    "Slice of Life" wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address=192.168.88.1/24 comment=defconf interface=ether2 network=\
    192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
    ether1
/ip dhcp-server lease
add address=192.168.88.73 client-id=1:2c:aa:8e:5:15:26 comment=wyze \
    mac-address=2C:AA:8E:05:15:26 server=defconf
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
    invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
/system clock
set time-zone-name=Europe/Vilnius
/tool mac-server
/tool mac-server mac-winbox
Jotne
Sun Apr 21, 2019 11:13 am
I do guess that wyze cam works as any other modern device.
You connect it on your inside LAN. Camera then connect to a cloud server.¨
When you are on a public internet, you connect to the cloudserver and see your camera info.
So no NAT, not port forwarding are needed. Just connect, register, sign inn etc.
If you on other hand have a high end camera like Axis and would like to stream directly from it, you need to forward a port to it. (if you do not get a high end software solution for it)
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
anav
Sun Apr 21, 2019 4:55 pm
192.168.88.0
You are in a conflict situation.
sol'n
192.168.88.0
ignasand
Mon Apr 22, 2019 9:51 am
192.168.88.0
sol'n
192.168.88.0
thank you for help. I've never changed anything in this (ip address) part of settings, just few time reset router to factory settings. It's strange that there is conflict situation.
Despite this, I changed the settings as you suggested.
After all situation is still the same. Device connects to router (attached screenshot, it's selected on wireless clients list), but didn't get access to internet (blinking blue led on divece indicates that there is no internet connection).
As I mentioned before, the only (as I know) way to work around this problem is to disable default NAT rule (action: masquerade) for approximetly 10s. Device connects as soon as I enalbe this rule.
Here is the yourconfig.rsc after the corrections:
# apr/22/2019 09:25:17 by RouterOS 6.43.8
# model = 951G-2HnD
/interface wireless
    192.168.88.0
/ip dhcp-client
    ether1
/ip dns static
    invalid
/system clock
/tool mac-server
Users browsing this forum: Majestic-12 [Bot] and 32 guests
