MUM Europe 2020
mikrotiklt
[super noob] Attempting to reconfigure the internet set up on my Mikrotik device
Tue Feb 26, 2019 5:42 pm
I'm trying to change the configuration of our Mikrotik device to connect to the internet via a new ISP modem-router with new ISP.
I'm a total noob. So please take it easy on me. I was not the person to originally set up the network, so i'm attempting to learn as i go.
Our old ISP provided us with a static IP address via a telephone line.
We used their modem but the Mikrotik device was set up to handle the PPPOE handshake/connection. I believe the ISP modem-router was put in to modem only mode?
If i go in to our Mikrotik, i can see the configuration for this including credentials.
Our new ISP provides us with a static IP address via a fibre cable and coax into the building.
Looking in the settings of the ISP modem-router, it appears like it handles the PPPOE handshake/connection without our intervention.
I've talked to the ISP and because of the type of connection we have, we are not able to put the new modem-router into modem only mode. Supposedly we need a dynamic IP or multi-static IP to allow us to put it in to modem only mode.
The new ISP modem-router provides us with 5 ethernet ports. It has DHCP, and UPNP IGD, and WLAN.
If i connect a computer to one of the ethernet ports, i can access the internet without any issue.
So, what i would like to do is share the internet connection from an ethernet port of the new ISP modem-router with the Mikrotik and everything that's attached to it.
How do i go about doing this?
I'm guessitmate that the connection between the Mikrotik and the ISP modem-router should be on ethernet1/internet of the Mikrotik.
I've disabled the DHCP server and the IGD ( I believe this does the NAT side of the device?).
I've got an image to highlight everything i know about the network - I've attached an image to this submission.
I would like the DHCP and DNS servers to remain on the server (Windows 2008 R2).
I've tried for a number of hours to attempt to get this working from info/tutorials i can find on the internet but i'm just not getting anywhere :/
Would love some help/guidance please?
I've attached the config with the sensitive information removed
jostoboy
Re: [super noob] Attempting to reconfigure the internet set up on my Mikrotik device
Mon Jan 13, 2020 2:10 pm
Hi
please i need help to reconfigure my mikrotik router 951 series. i configured it but it is only connection to just one device hence i decided to reconfigure it so it can be connected to more than one device. i reset the router using my win.box software but could not access the ip address of the default configuration setting which is 192.168.88.1/24.
please help me I'm stuck
Users browsing this forum: normis and 53 guests
