MUM Europe 2020
FHM
Speedtest.net error
Wed Mar 20, 2019 5:53 pm
Hi All
I have applied this topic and all is working fine except speedtest.net I have error
viewtopic.php?f=13&t=108771&sid=330b13e ... 5ec29d4f6d
when I disable it all is working
the error pic is in attach
Thanks for all
flaviojunior
Trainer
Trainer
Re: Speedtest.net error
Thu Mar 21, 2019 12:29 pm
Hi All
Thanks for all
Hi dear, there is no fault on the configuration probably is something on PC or in the browser. To confirm it just put any basic router to the internet and see if it continues to confirm
:D
Sent from my Vivo XI+ using Tapatalk
Mikrotik Certified Trainer, Network Specialist.
Number 1 consultant Brazil, Rio de Janeiro
MTCNA, MTCRE, MTCWE, MTCTCE, MTCUME, MTCIPv6E, MTCINE, MTCSE
FHM
Sat Mar 23, 2019 4:19 pm
The problem has been solved
Distance number has been changed from 1 to 2
I do not know if they are the solution but the problem has gone
Thanks for All
Users browsing this forum: No registered users and 38 guests
