caiovernaglia
Port forward on port 8080
Fri Mar 22, 2019 2:17 am
Helo guys.
Im having a trouble trying to port forward port 8080
I have a webserver and when a try to redirect wab traffic to him, mkt router dont forward.
If i set the listening port to 8081, for example, and add a nat dstnat rule to 8081 it works fine.
I realized that the mkt proxy works on port 8080 but, proxy is disabled. I've already triple checked that on ip>proxy
My nat rules are:
ip firewall nat
add chain=dstnat protocol=tcp dst-port=8080 action=dst-nat to-addresses=192.168.230.250 to-ports=8080 comment="portal webserver" disabled=no
Along that, a have another nat rule to another webserver (on other port) thats works fine
ip firewall nat
add chain=dstnat protocol=tcp dst-port=9090 action=dst-nat to-addresses=192.168.100.251 to-ports=9090 comment="os dashboard" disabled=no
Anyone have an idea to how make de mkt dont think that port 8080 is for proxy??
Thanks all!!
anav
Re: Port forward on port 8080
Fri Mar 22, 2019 1:35 pm
You need to include the in-interface=eth1-wan in your destination nat rule.
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
Sob
Fri Mar 22, 2019 2:14 pm
That's not it. There's no special treatment for proxy. Even if it was enabled, dstnat rule would override it. Enable logging for the rule and see if there are matching packets. If not, it could be ISP doing some filtering. If you see them coming, it's your config, either on router or on target device.
@anav: That's not it either. It's not ideal to have no specification of destination, but not having it is not what breaks things in this case.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
anav
Fri Mar 22, 2019 2:49 pm
Sigh...........I long for the day.
@anav: Finally, disciple anav you have snatched the pebble from my hand. You may go forth into the world and get paid for MT configurations. :-)
Sob
Fri Mar 22, 2019 3:05 pm
Maybe one day... but it will require updated strategy, something a little more advanced than "I have it in my config and you don't, so maybe try to add the same to yours". ;)
anav
Fri Mar 22, 2019 3:21 pm
You have a point, lets get rid of nationalism, religion (and my configs) and share our cultures through food and alcohol. This is the path towards one peoples, peace and fullfilment!!
Sob
Fri Mar 22, 2019 3:31 pm
I don't know where all those things came from, and I have nothing against your configs. I'm just saying that I'm reading a lot of your posts and some of your advices are more trial & error suggestions than they could be, if you read the manual first. :)
anav
Fri Mar 22, 2019 3:45 pm
The alternative is post nothing. I learn by trial and error LOL ( I must be human ) . Reading as much as I can but if I dont understand,,,,,,,,,,,,,
Its not a manual its a cryptic scroll in an ancient forgotten language.
mkx
Fri Mar 22, 2019 3:48 pm
Why's this such a dreadful option?
BR,
Metod
k6ccc
Fri Mar 22, 2019 5:21 pm
Two thoughts. First, do your firewall rules allow the port forwarding? If you have an "all all DST-NAT" rule in the forward chain, that would take care of it, but if you don't do that, you generally need to specifically allow the forward. This is not likely the case since port forwarding worked on port 8081, so you either have the first allow rule or you added a specific one.
Second, could your ISP be blocking port 8080? You could add a counter rule early in your forward chain to make sure that packets are actually arriving at the router. Those can be very helpful in troubleshooting. Here is an example of one of mine:
add action=passthrough chain=forward comment=\
    "Counter for inbound UDP port 32222 packets to Black Forest GRIL" \
    connection-state="" dst-port=32222 in-interface=E1-p2_Cable_Internet \
    protocol=udp
Obviously, that rule needs to be before any other rule that would allow the packet (such as an "allow all established and related" packets).
RB750Gr3, RB750r2, CRS326-24G-2S (in SwitchOS), CSS326-24G-2S, CSS106-5G-1S, RB260GS
Not sure if I beat them in submission, or they beat me into submission
Jim
caiovernaglia
Fri Mar 22, 2019 5:44 pm
My isp don't block 8080, i've tryed a port forward on 8080 with a dlink router and works fine.
I've tried a passthroug rule to see if the counter go high, and it doesnt.
Logging the rule doesnt return nothing.
k6ccc
Fri Mar 22, 2019 6:10 pm
There is something being missed here. Export your configuration and post it.
/export hide-sensitive
Jim
solar77
Fri Mar 22, 2019 6:43 pm
Ha .... :lol:
sorry, in the business of helping OP. if the dst-nat rule has no traffic passing through, you need to check why the traffic is not reaching. complete config would give us more idea
MTCNA MTCTCE UEWA
caiovernaglia
Sat Mar 23, 2019 12:47 am
For tests, i've no rules at all. Just dstnat to 8080 and another to 8081.
As said, 8081 works.
Sob
Sat Mar 23, 2019 4:02 am
You already got the hint about logging, so expand it a little:
/ip firewall mangle
add action=log chain=prerouting dst-port=8080,8081 log-prefix=1 protocol=tcp
add action=log chain=postrouting dst-address=192.168.230.250 dst-port=8080,8081 log-prefix=2 protocol=tcp
add action=log chain=prerouting log-prefix=3 protocol=tcp src-address=192.168.230.250 src-port=8080,8081
And then see where exactly is the difference between 8080 and 8081.
Users browsing this forum: No registered users and 7 guests
