Zetera
CCR MikroTik configuration
Tue Apr 02, 2019 9:31 pm
Need to configure a mikrotik to reflect the following:
What is needed is one port as a WAN uplink thru which one can assign a static public to the Mikrotik, and a second port that is also "connected" to the circuit to which will connect to a switch to be used to connect devices that will use a static public IP address. The other ports are all LAN ports with private DHCP assignments.
Is there anything I can look at to accomplish this or is there a simple configuration that can get me by for the time being?
Zetera
Re: CCR MikroTik configuration
Wed Apr 03, 2019 4:59 pm
Any possible assistance on this? Or can anyone point me in the right direction?
Sob
Wed Apr 03, 2019 6:12 pm
Do you mean that you need one public address on RB and other public addresses on other devices connected to RB, and to them it should be as if RB wasn't there? If that's the case, you want to create bridge with two ports, one connected as uplink and the other to switch with the rest of devices. Assign router's public address to this bridge and it will be your WAN port.
Zetera
Wed Apr 03, 2019 6:17 pm
Is there an example config to work from that you'd be able to send my way please? If not that's fine I can probably move from here. Thanks either way.
anav
Wed Apr 03, 2019 6:35 pm
Your communication skills are clearly lacking so yes please carry on without assistance.
If you need help please provide a diagram to help us understand what the network looks like and post a config when ready for review
/export hide-sensitive file=yourlatestconfig
Zetera
Wed Apr 03, 2019 6:55 pm
This is my current configuration.
# apr/03/2019 11:49:21 by RouterOS 6.44.1
# software id = IF8Y-2BLH
# model = CCR1036-8G-2S+
# serial number = 6AAE05716373
add name=bridge1
add name=WAN
add name=LAN
add name=dhcp ranges=192.168.88.2-192.168.89.254
add address-pool=dhcp disabled=no interface=bridge1 lease-time=1d10m name=\
    dhcp1
add address-pool=dhcp disabled=no name=dhcp2
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
add disabled=yes interface=sfp-sfpplus1
add interface=sfp-sfpplus1 list=WAN
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=ether6 list=LAN
add interface=ether7 list=LAN
add interface=ether8 list=LAN
add list=LAN
add address=192.168.88.1/23 comment=defconf interface=bridge1 network=\
    192.168.88.0
add address=192.168.88.1/23 interface=ether1 network=192.168.88.0
add address=74.218.160.34/27 interface=sfp-sfpplus1 network=74.218.160.32
/ip dhcp-client
add dhcp-options=hostname,clientid interface=sfp-sfpplus1
add address=192.168.88.0/24 gateway=192.168.88.1 netmask=24
add address=192.168.88.0/23 gateway=192.168.88.1 netmask=23
set servers=4.2.2.4,8.8.4.4,24.25.5.61
    established,related,untracked
    invalid
add action=accept chain=input comment="defconf: accept ICMP" protocol=icmp \
    src-address-list=allow_list
add action=accept chain=input src-address-list=allow_list
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add distance=1 gateway=74.218.160.32
/system clock
set time-zone-name=America/New_York
/system identity
set name="MikroTik Lab"
Sob
Re: CCR MikroTik configuration  [SOLVED]
Thu Apr 04, 2019 12:54 am
It's a little wrong, 192.168.88.1/23 on bridge1 and same 192.168.88.1/23 on ether1 (port of the same bridge) doesn't make sense, it should be only on bridge1.
As for the change you need, it's really simple:
- create new bridge
- add sfp-sfpplus1 (current WAN port) to this bridge
- this bridge becomes your new WAN port, so change it where necessary (move the public IP address to it, add it to WAN interface list)
- choose the port for other devices and move it from bridge1 to new bridge
Zetera
Thu Apr 04, 2019 11:25 pm
thanks sob! This helped loads! :)
Users browsing this forum: rplant and 82 guests
