ceylan
alternative to scheduler
Wed Apr 10, 2019 2:53 pm
for example i am writing any script as follows...
system script add .....
/interface ethernet monitor ether1 once do={
:if ($rate = "10Mbps") do={
/system.........
or
i want to get sms instant by the router when any user is active
script is working when i press "run script" button. but i want the script always check the variables and when rate =10Mbps start do command.i know i can use "system scheduler" bu i want to know if i have another possibility?
pe1chl
Re: alternative to scheduler
Wed Apr 10, 2019 3:34 pm
In this case, no.
In other places there is sometimes the option to run a script when a certain event occurs, e.g. a PPP connection is made, a DHCP lease is issued, etc.
But not for ethernet connection.
AlainCasault
Trainer
Trainer
Wed Apr 10, 2019 3:56 pm
Actually, you could use netmonitor.... I think that's what it's called.
Once you reach a threshold, either in our out, the script is run.
Sent from my cell phone. Sorry for the errors.
___________________________
Alain Casault, Eng.
If I helped you, let me know!
ceylan
Wed Apr 10, 2019 4:33 pm
mmm I understand.. no alternative :(... i still like MİKROTİK :) Thnks for support...
pe1chl
Wed Apr 10, 2019 4:38 pm
Traffic Monitor... but that monitors the actual transmit/receive bitrate, not the negotiated rate of ethernet.
May you can somehow use it.
ceylan
Wed Apr 10, 2019 5:01 pm
YES İ USE TRAFFIC MONITOR... THNKS
Users browsing this forum: Google [Bot] and 25 guests
