MUM Europe 2020
gutekpl
Is routing package doing anything more beside things contained in Routing menu on the left?
Thu Apr 11, 2019 9:52 pm
I am doing some cleaning on my hAP Ac^2 configured as main router with capsman running on it. I have already disabled ipv6, hotspot, mpls and advanced-tools. I checked Routing submenus on the left and I have nothing configured there, so I am wondering can I disable it and if yes is it safe to disable it? Won't it interfere negatively for example on firewall, etc.?
Thanks for any info.
mkx
Re: Is routing package doing anything more beside things contained in Routing menu on the left?  [SOLVED]
Thu Apr 11, 2019 11:01 pm
Package routing provides advanced routing functionality (e.g. BGP, OSPF, ...) which is not used on typical SOHO device.
My main router (hAP ac2 as well) doesn't have that package installed at all and it still works just fine.
BR,
Metod
Users browsing this forum: No registered users and 46 guests
