cipirix
Help 2 Wan 2 lan
Fri Apr 12, 2019 12:06 am
Hello, i need help with the following problem:
I have 2 ISP and i want to broadcast 2 wireless ssid's one for each provider. Any ideas on how to do that. I don't need load balancing the two isp's must work together.
anav
Re: Help 2 Wan 2 lan
Fri Apr 12, 2019 2:57 pm
The requirements are not well understood.
a. you have two isps
b. you have one MT router model?
c. you wish to have two wifi networks, (two SSIDs) with each being serviced by one ISP
(isp1- ssid1, isp2 -ssid-2)
What subnets do you have on the router, can we assume three subnets?
1- wired normal use subnet a
2- ssid-1 subnet b
3. ssid-2 subnet c
Diagrams would help
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
cipirix
Fri Apr 12, 2019 11:26 pm
Hi, I've made a diagram of the problem.
Yes,I have two ISP, the Router model is RB1100ahx2, and i wish to have two separate ssid's on the access point one for each provider.
The AP's are Unifi AC-LR that support two ssid'd and vlan.
For the moment the Router is configured as Fail over but my client does not want this configuration. He wants to have both ISP's on the AP
There is limited wired connection for DVR and access control.
igpetkov
Sun Apr 14, 2019 10:35 am
I hope this will help you:
https://www.youtube.com/watch?v=m6tYANGC9o0
You have to set two LANs and to mark trfic through them. then have to set routes for both marks
Users browsing this forum: No registered users and 58 guests
