MarHazK
RB2011UiAS-RM WAN not achieve 1GBps
Sat Apr 20, 2019 9:12 am
Can anyone share best tips/configurations for RB2011UiAS-RM able to get 1GBps?
We have internet speeds D/U at 1GBps with Cat6 installed from ASUS RT-AC66U link to to RB2011UiAS-RM's WAN eth1 then from rb2011UiAS-RM LAN eth2-5 to all the 4 PCs, but...
sadly, when I do the speedtest, I just received 200Mbps-400Mbps on PC Client side that also use Gigabit Ethernet + cat6 that connected to the RB2011UiAS-RM.
If I directly connect the PC to ASUS RT-AC66U, I able to get 800MBps-1GBps.
I heard probably because of fasttrack etc. but still caused the same result.
Steveocee
Re: RB2011UiAS-RM WAN not achieve 1GBps
Sat Apr 20, 2019 9:27 am
The answer will undoubtedly be you need to use fast track but an example of your config is needed to ensure it's been put into place correctly.
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
tesme33
Mon Apr 22, 2019 8:43 am
hi
just case you need some info on fastrack.
https://wiki.mikrotik.com/wiki/Manual:IP/Fasttrack
And another topic. The order of the Firewall rules also have a heavy impact on the performance, the earlier the firewall can decide that a connection is allowed to pass the router the better.
erlinden
Mon Apr 22, 2019 10:38 am
What is the purpose of the RB if you already have an Asus router?
tesme33
Mon Apr 22, 2019 11:14 am
Hi
i just did a quickcheck.
PC (W10)- 1GBit LAN - Switch (Netgear Gigbit) - RB2011/port1 (IP via DHCP) - RB2011/Port3 (bridge) - 1GBit LAN - Laptop (W10)
RB2011 is on 6.43.14
With default config(e.g. RESET config) i can achieve the following with iperf3. CPU load goes up to 80%.
Connecting to host 10.213.213.125, port 5201
[  4] local 192.168.88.254 port 3988 connected to 10.213.213.125 port 5201
[ ID] Interval           Transfer     Bandwidth
[  4]   0.00-1.00   sec  2.44 GBytes  21.0 Gbits/sec
[  4]   1.00-2.00   sec   100 MBytes   840 Mbits/sec
[  4]   2.00-3.00   sec   104 MBytes   873 Mbits/sec
[  4]   3.00-4.00   sec   103 MBytes   864 Mbits/sec
[  4]   4.00-5.00   sec   101 MBytes   850 Mbits/sec
[  4]   5.00-6.00   sec   102 MBytes   856 Mbits/sec
[  4]   6.00-7.00   sec   102 MBytes   857 Mbits/sec
[  4]   7.00-8.00   sec   102 MBytes   857 Mbits/sec
[  4]   8.00-9.00   sec  97.9 MBytes   821 Mbits/sec
[  4]   9.00-10.00  sec   102 MBytes   858 Mbits/sec
[  4]   0.00-10.00  sec  3.34 GBytes  2.87 Gbits/sec                  sender
[  4]   0.00-10.00  sec   983 MBytes   825 Mbits/sec                  receiver
iperf Done.
And in reverse mode.
Reverse mode, remote host 10.213.213.125 is sending
[  4] local 192.168.88.254 port 4042 connected to 10.213.213.125 port 5201
[  4]   0.00-1.00   sec  89.6 MBytes   751 Mbits/sec
[  4]   1.00-2.00   sec  81.5 MBytes   684 Mbits/sec
[  4]   2.00-3.00   sec  91.5 MBytes   768 Mbits/sec
[  4]   3.00-4.00   sec  85.9 MBytes   721 Mbits/sec
[  4]   4.00-5.00   sec  88.4 MBytes   742 Mbits/sec
[  4]   5.00-6.00   sec  92.6 MBytes   777 Mbits/sec
[  4]   6.00-7.00   sec  92.0 MBytes   772 Mbits/sec
[  4]   7.00-8.00   sec  82.5 MBytes   692 Mbits/sec
[  4]   8.00-9.00   sec  85.2 MBytes   715 Mbits/sec
[  4]   9.00-10.00  sec  85.7 MBytes   719 Mbits/sec
[  4]   0.00-10.00  sec   875 MBytes   734 Mbits/sec                  sender
[  4]   0.00-10.00  sec   875 MBytes   734 Mbits/sec                  receiver
iperf Done.
Users browsing this forum: No registered users and 25 guests
