dan5544
portforwarding issue
Wed May 01, 2019 11:35 am
hello portforwarding is done on mikrotik sxt but when i try to chek port from https://ping.eu/port-chk/ to see port is open or no it show me close port dunno why im sure my port forward is true (192.168.1.111 is laptop lan static ip ) any help pls ?
mkx
Re: portforwarding issue
Wed May 01, 2019 7:12 pm
Check PC's firewall ... does it allow inbound connections from internet?
BR,
Metod
anav
Wed May 01, 2019 8:43 pm
A closed port is what should be showing, the fact that it is visible indicates it is being seen from the Web.
A port that does not show at all would be a different matter.
a. forward rule not present need to add to config OR
b. NAT rule has narrowed down allowed IPs by source address and this renders the port invisible to scans (normal behaviour).
Your pics do not show the necessary forward chain firewall rules but I am assuming it is in place (as covered off by default rules).
Call a friend and ask to try out whatever your service you are providing as a test!!!
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
dan5544
Wed May 01, 2019 10:00 pm
yes i did port forwarding on firewall too
dan5544
Wed May 01, 2019 10:04 pm
isp told me u must open the client then after that u will see port is open i try that then i saw diffrent ports connected when i monitor game pls look at image
the port forwarding for my game is
TCP: 27015-27030,27036-27037
UDP: 4380,27000-27031,27036
this ports added on mikrotik and windows firewall
pls look at ports on monitor when client is open when im in server there is not even 1 of this ports !!!!
anav
Thu May 02, 2019 2:29 pm
Very few games these days require any port forwarding, which game is it?
Also post complete config
/export hide-sensitive file=yourconfigmay02
dan5544
Fri May 03, 2019 7:29 pm
hello idk why nat type in game is still moderate not open if portforwarding is true
dan5544
Sat May 04, 2019 5:45 pm
anav
Sat May 04, 2019 10:09 pm
Your config is hosed and needs work.
When I get time I will have a closer inspection.
Users browsing this forum: No registered users and 39 guests
