teeemo
Port forwarding: in-interface (not working) vs in-interface-list/dst-address (working)?
Sat May 04, 2019 4:01 pm
I am trying to port forward port 80, towards an internal PC of mine (192.168.50.50). I am using a MikroTik hap ac2, using RouterOS 6.43.14
Now, I tried the nat way of doing it (not sure if others exist), however, only 2 out of 3 options I tried work (see last part of rule):
  • In-interface-list=wan:
    action=dst-nat chain=dstnat dst-port=80 log=yes protocol=tcp to-addresses=192.168.50.50 to-ports=80 in-interface-list=WAN
  • dst-address=mypublicip:
    action=dst-nat chain=dstnat dst-port=80 log=yes protocol=tcp to-addresses=192.168.50.50 to-ports=80 dst-address=mypublicip
  • in-interface=ether1
    action=dst-nat chain=dstnat dst-port=80 log=yes protocol=tcp to-addresses=192.168.50.50 to-ports=80 in-interface=ether1
Out of those, the last one doesn't work, but I've checked the list of services and WAN=ether1:
add comment=defconf name=WAN
add comment=defconf name=LAN
This is my currently (working) configuration:
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=dst-nat chain=dstnat dst-port=80 in-interface-list=WAN log=yes protocol=tcp to-addresses=192.168.50.50 to-ports=80
What am I missing that the in-interface variant doesn't work, but the other one(s) do?
anav
Re: Port forwarding: in-interface (not working) vs in-interface-list/dst-address (working)?
Mon May 06, 2019 7:57 pm
Hard to say since you didnt post your entire config and thus are missing relevant bits.
What interface is ppp0e-1 defined as???? Try that instead of eth1
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
Exiver
Tue May 07, 2019 9:19 pm
It looks like you are using a pppoe-connection. That means the active pppoe-connection is an additional "interface" on your router. ether1 is only the physical link but not the interface where your router receives the traffic coming from the internet. Thats why your interface-list works (ether1 AND pppoe-out1). Rule two works because the firewall isnt matching the packet based on the incoming interface but on your ip. If your ip address changes you would need to reconfigure rule 2 since obviously the ip-address isnt matching anymore. Rule 1 (or rule 3 with pppoe-out1 as in-interface) would not require you to reconfigure anything if your ip changes.
teeemo
Sat May 11, 2019 9:10 pm
Oh, I found it out later, but couldn't update my post. It seems indeed, that pppoe-out1 is doing/having the traffic instead of eth1, that's why the list works since it includes the pppoe-out1
Thanks!
Users browsing this forum: MSN [Bot] and 31 guests
