jojodim
Plex Media Server Remote Access - Port Forwarding
Sun May 12, 2019 12:46 am
Hey guys,
I am new to the forum. I recently installed a Mikrotik router in my home. Everything seems to be working great except the Remote Access feature on my Plex Media Server won't work any longer. I have literally spent hours trying to troubleshoot the issue. Apparently it is a Port Forwarding problem. However, when I try and add the NAT rule, it still doesn't work. I have turned off and on the UPnP and nothing happened, tried making the computer IP address static, and also changed the settings on the Windows 10 firewall. None of these things worked. When I toggle the Remote Access on in the PMS settings, it stays green for 5-10 seconds and then says the connection was lost. I've literally spent 20 or more hours trying to figure this out.
Any help would be appreciated
inteq
Re: Plex Media Server Remote Access - Port Forwarding
Sat May 18, 2019 5:21 am
Use https://www.grc.com/x/ne.dll?bh0bkyd2 to test your ports.
Plex is drunk most of the time.Their devs even more so.
If you search on their forums you will find plenty of other users with this problem.
If you did the port forward and https://www.grc.com/x/ne.dll?bh0bkyd2 shows 32400 open, there is nothing you can do to fix what PlexWeb shows/reports.
anav
Sat May 18, 2019 5:34 pm
Please post your config and then we can sort out (or isolate the router from being the problem) the issue.
/export hide-sensitive file=youconfigmay18
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
rossomike1966
Tue May 21, 2019 11:08 am
even I can't access plex from the outside
clearly it must be a port forwarding problem
(the plex port is 32400 as suggested by them)
this is my configuration
I tried to make a NAT RULE, but without success.
now I took it off to start from scratch.
thank you
Sob
Tue May 21, 2019 3:38 pm
Are you sure you have public address (i.e. not 10.x.x.x, 192.168.x.x, 172.16-31.x.x, 100.64-127.x.x) on your router? Without it, no port forwarding will help you.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
rossomike1966
Tue May 21, 2019 4:25 pm
how can i check this in my winbox? i see a public address in PLEX page..do you mean it?
anav
Tue May 21, 2019 4:36 pm
Why would you have a public IP on the plex??
Sob
Tue May 21, 2019 4:57 pm
Look in IP->Addresses and there will be all addresses on router, static and dynamic.
@anav: I guess it probably shows the public address used to access internet, there's always some, but it can be on ISP's router.
rossomike1966
Tue May 21, 2019 5:03 pm
for my network on LTE1 it shows Dynamic..
Sob
Tue May 21, 2019 5:15 pm
But is it public or not (see the ranges I posted)?
rossomike1966
Tue May 21, 2019 5:18 pm
public
Sob
Tue May 21, 2019 11:35 pm
I don't know Plex, but quick search suggests that it supports UPnP, you have it enabled, so it should work. Check if it adds dynamic dstnat rule to router (maybe you'll have to restart it or find some other way to force it to open port). If it adds the rule, try to access it from outside and see if rule's packet counter increases.
florid
Wed May 22, 2019 7:02 am
you can test port forwarding work or not by put a new system with the required port open.
I experienced similar Plex Media Server Remote access flashing issue recently, and ends up with forgetting to allow the port on the Plex system itself (Synology DSM Firewall blocked it).
RouterOS port forwarding is quite straight forward, you can enable logging of the NAT rule to see any hit from Internet.
Docop
Fri May 24, 2019 3:02 pm
Hi here is 2 rule that i've found. I got problem with order, but these might work.
21    ;;; Plex Ports - TCP
      chain=forward protocol=tcp dst-port=3005,8324,32469
22    ;;; Plex Ports - TCP
      chain=forward protocol=udp dst-port=1900,5353,32412-32414
Can you post your / firewall filter and firewall nat / firewall nat print... ?
jojodim
Tue Jun 04, 2019 5:10 pm
Had to get on-site support from an IT friend of mine, but finally got it to work. See Attached screenshot of NAT Rule-> IP/Firewall/NAT/Add New
jojodim
Thu Aug 01, 2019 5:17 pm
Forgot to mention, under the "Action" tab
Action-> "dst-nat"
To Addresses-> "192.168.00.000"
To Ports-> "32400"
Users browsing this forum: No registered users and 36 guests
