fabieng
A little help to configure a NAT
Tue May 14, 2019 10:53 am
Hello ,
I'm facing a unusal case today . for a network i'm trying to install
the devices are connected to the same network with fixed ip's ,
some are using GW1 and other GW2 in their network setting.
i given two IP's to my bridge where the devices are connected
i need help to configure a nat firewall ,
i just want write some nat rules to forward to gw1(192.168.0.1) when 192.168.2.1 is used as gateway
and an other to forward to gw2(192.168.0.2) when 192.168.2.2 is used as gateway
i know this is quite unusual , but the devices have specials settings that make them switch gateway from time to time to load-balance.
Because of this this is important that the devices continue accessing the gateways from two differents ip's
Sob
Re: A little help to configure a NAT
Tue May 14, 2019 9:27 pm
Anumrak
Forum Veteran
Forum Veteran
Wed May 15, 2019 11:38 am
Why just don't use VRRP or VRRP+OSPF?
fabieng
Sat May 18, 2019 11:17 am
Hello Sob , thanks you , i didn't know about VRRP,
i will try to implement that solution monday
thaks
Users browsing this forum: No registered users and 19 guests
