guestph
Telnet Response after admin login
Tue May 14, 2019 12:52 pm
i need help with decoding the response send by the Mikrotik after a successful login via Telnet. Supposedly i'll get response after typing "ip address print", but i get strange characters for the response. i get this response "p [9999B [9999B Z [6n".
i have this code for printing the response.
Question:
What type of response does Mikrotik send after a successful login via Telnet, is it String or Char or ???
Badly need help with this one.
pe1chl
Re: Telnet Response after admin login
Tue May 14, 2019 2:40 pm
Those are ANSI standard escape sequences that are used to do cursor movement, set colors, etc.
You can do a telnet login with options to disable that.
See the wiki: https://wiki.mikrotik.com/wiki/Manual:C ... in_process
nescafe2002
Long time Member
Long time Member
Tue May 14, 2019 3:04 pm
If you want to automate configuration tasks, you'd better use the built in API functionality (or SSH at least).
https://wiki.mikrotik.com/wiki/Manual:API
Users browsing this forum: No registered users and 6 guests
