emanuelebruno
Bruteforce login prevention doesn't work
Wed May 15, 2019 12:57 pm
Hi to all, according to this link https://wiki.mikrotik.com/wiki/Brutefor ... prevention it could be possible to block unauthorized access like fail2ban.
I have chr-installed RouterOS https://download2.mikrotik.com/routeros ... .3.img.zip in a VPS and it works great!
At firt, it seemed to work properly, but after the fourteenth ban, the system simply stopped working.
Is it a limitation of the "FREE VERSION" ?
Thank for your help!
Anumrak
Re: Bruteforce login prevention doesn't work
Wed May 15, 2019 1:58 pm
Hey. Are you sure that all 5 rules added to your firewall section in right order? Like drop, blcklst, s3,2,1. Drop on the top and the stage 1 on the bottom.
Users browsing this forum: No registered users and 3 guests
