MUM Europe 2020
FHM
RB3011 Show LTE in Quickset
Tue May 28, 2019 5:17 pm
Hi
I have put USB LTE in my RB3011 and I have removed now, but the Quickset still show LTE in it and "ethernet" option disappear and no more option in it, only LTE
Thanks All
krafg
Re: RB3011 Show LTE in Quickset
Thu May 30, 2019 8:34 am
Reboot and try again.
Regards.
If you want to know my network, you can find it here.
FHM
Thu May 30, 2019 11:26 am
Regards.
Thanks for reply
Nothing happened, the problem still exists
mkx
Thu May 30, 2019 2:00 pm
How about factory reset?
BR,
Metod
FHM
Thu May 30, 2019 6:16 pm
No I don't want to make a factory reset, because there are many settings I do it in RB
There is a problem and factory reset is not a solution
3liswaid
Thu May 30, 2019 7:21 pm
i have the same problem
my router is hEX
Note that: my friend also has a hEX and the problem didn't appear for him..
i believe that that problem has appeared after i connect my phone to the router and enabled the Tethering.
FHM
Thu May 30, 2019 8:25 pm
my router is hEX
The problem appears if a phone is connected via a USB connection, and activating the phone as a LTE modem or connecting a USB LTE modem dongle
mkx
Thu May 30, 2019 10:52 pm
If you have many custom settings, then you should most definitely not use quickset. If you can still sensibly change settings using quick set, then ... you don't have that many settings after all.
BR,
Metod
FHM
Fri May 31, 2019 5:23 pm
I'm sorry but reset is not a solution
jlp16400
Fri May 31, 2019 5:37 pm
I have the same problem on my RB3011uias....;)
Cha0s
Forum Veteran
Forum Veteran
Fri May 31, 2019 5:47 pm
Then you shouldn't use Quickset.
Quickset is only for initial setup of a device. If you do custom configuration afterwards then you will only get problems with Quickset.
Steveocee
Mon Jun 03, 2019 4:04 pm
Unhelpfully I'll echo the above. If the device is up and running and you can't bare to lose the config.
1)Back up your config NOW
2)Make changes manually and don't use quickset again
3)If you mess it up badly at least you have a backup now.
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
Chiditron
WInBox Shuts down whenever I click on Quickset
Tue Jun 25, 2019 12:47 pm
I have a Mikrotik RB951Ui-2HnD Indoor Wireless Router and I installed winbox.
However, whenever I login to my winbox and click on Quickset to configure my network, the winbox shuts down.
How do I congigure my router without quickset
I need ideas please.
CHiditron
Steveocee
Re: WInBox Shuts down whenever I click on Quickset
Fri Jun 28, 2019 12:48 pm
CHiditron
Maybe try this posting.php?mode=post&f=13
Users browsing this forum: astraliens, Google [Bot] and 52 guests
