Suby
RB4011iGS+5HacQ2HnD-IN low net speed
Tue Jun 04, 2019 9:23 pm
I would like to ask a little help from veteran users of MikroTik. So I have a RB4011iGS+5HacQ2HnD-IN router and I have set it. It goes well but I have a little problem. it is my net speed. I have 1Gb net and when I measure net speed with bandwidth-test I have seen thet the net speedd is okay about 700 - 900 Mb/sec. When I measure net speed bettween about two pc the net speed is okay about 700 Mb/sec.
But when I measure net speed from my computer (for example: https://www.speedtest.net/) net speed is very low. It is under 100 Mb/sec usually 90-95 Mb/sec.
I think that my setup is wrong.
Please give me some advise to correct it.
I am a beginner mikrotik user.......
Thank you for your help.
Best regard,
Suby
mkx
Re: RB4011iGS+5HacQ2HnD-IN low net speed
Tue Jun 04, 2019 9:28 pm
Post output of command /export hide-sensitive inside [ code] environment ... redact public IP address if any.
BR,
Metod
miltont
Wed Jun 05, 2019 12:53 am
Im also having this issue in 1 of the servers that i have in my network, i verified the server and the NIC Card was @100MB Speed, and i didnt noticed it, everytime i speedtested
my DIA of 500Mbps will result with 96Mbps of Download and Upload. I changed the network adapter to a 1GB and now i speedtested and have almost 300Mbps of download and Upload.
I know that i should have almost the 500Mbps, im checking the NIC Properties to see if i have to disable something that is restricting the NIC Card to reach the 500Mb Speeds.
Suby
Wed Jun 05, 2019 8:27 am
Dear mkx,
Thank you for your answer.
I have run the command what you suggested. I got a log0.txt file.
I attached it for you.
I hope it will be to help to find the mistake.
Best regards,
Suby
Suby
Wed Jun 05, 2019 8:34 am
Dear Miltom,
Thans your experience. But my router is new and the specification has that it can download/upload datas with 1Gb/s. So I do not understant the mistake.
I think that my router setting has any mistake.
Best regards,
Suby
mkx
Wed Jun 05, 2019 1:51 pm
That's a very weird outcome of running the command I wrote. So far it every time (even for other members of this forum) produced output (flushed on terminal window) which typically starts like this:
# jun/05/2019 10:49:56 by RouterOS 6.44.3
# software id = 1F7N-9ZNV
# model = RBD52G-5HacD2HnD
# serial number = 8FDE09EE9E2D
add admin-mac=BA:69:F4:20:A5:49 auto-mac=no comment=defconf name=bridge \
    protocol-mode=none vlan-filtering=yes
# ... etc
BR,
Metod
Suby
Thu Jun 06, 2019 8:12 am
Dear mkx,
Thank you for your advice but I do not understand what should I do....... Yesterday I tried that I set back router to basic factory AP and I added to it a 'pppoe' net conection. I measured the net speed again. But the result was same upload and download are 92 - 97 Mb/s.
I am very bushed.
Today evening I will connect with a laptop  straight to gigi moden without router and I will measure net speed than.
Best regards,
Suby
# ... etc
Users browsing this forum: Google [Bot] and 38 guests
