RackKing
DHCP reservation in or out of Pool/Scope?
Thu Jun 06, 2019 2:54 pm
This is more of a subjective questions, but...
I want comment out some the DHCP leases the router is giving out. Most of the time this is done in conjunction with assigning a specific IP address outside of the pool/scope. I am not as concerned with what the IP address is - simply who/what the host is.
Do you typically move these outside your pool/scope or leave them in it? I don't think it really matters as the router will not hand out that in-scope address for that host if it sees a reservation ... right?
Thanks in advance.
RackKing
Re: DHCP reservation in or out of Pool/Scope?
Fri Jun 07, 2019 1:30 am
Any ideas?
Jotne
Fri Jun 07, 2019 8:05 am
Its not clear what you want.
I convert all DHCP for my small net to static IP, then add DNS names for them. This way all units get the same IP all time and with a understandable name.
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
mkx
Fri Jun 07, 2019 9:28 am
My SOP is to move static leases out of pool range, which then effectively acts as address pool for (yet) unknown devices. Additional benefit is that I can tell if device is known to me from its IP address.
On most sites I run internal DNS (on separate small server) ... so when I set static DHCP lease, I also add (by hand) that device to DNS system.
BR,
Metod
RackKing
Fri Jun 07, 2019 10:45 am
Thanks guys - that was what I was looking for.
Jotne
Fri Jun 07, 2019 7:46 pm
This you can do on the MT Router itself. No need for an external server.
MikroTik->Splunk
mkx
Fri Jun 07, 2019 11:35 pm
I know ... and that's not the point.
BR,
Metod
k6ccc
Sat Jun 08, 2019 7:19 am
I'm the same as all the rest here. All known DHCP clients are given a DHCP reservation outside of the IP Pool. Most of the pools are only 10 IPs (and in reality, I could normally get away with one or two).
RB750Gr3, RB750r2, CRS326-24G-2S (in SwitchOS), CSS326-24G-2S, CSS106-5G-1S, RB260GS
Not sure if I beat them in submission, or they beat me into submission
Jim
Users browsing this forum: MSN [Bot] and 4 guests
