darkuek
Hacked recently
Mon Jun 10, 2019 12:39 pm
Hello, some of my accounts got hacked i start enabling 2FA. i wonder if my Forwarding played a role and if the hacker could access my router and bridge settings and edit/add rules.
Ports 0-65535 TCP and UDP
Best regards.
krafg
Re: Hacked recently
Wed Jun 12, 2019 7:42 pm
Update your ROS to latest version and change admin password.
Regards.
craigreilly
Re: Hacked recently
Wed Jun 12, 2019 8:37 pm
change the username too...
anav
Re: Hacked recently
Wed Jun 12, 2019 11:23 pm
Incorrect advice, first we dont know what firmware he had to begin with so its an assumption not fact if his firmware is or is not up to date.
Secondly, if there is hacked firmware the only 'safe' method for an update or reset is to dowload a clean copy of the latest firmware and apply it via netinstall!!
As to the setup, it appears you have attempted to create a "DMZ" to one of your PCs. Basically forwarded all ports to one device.
In general thats a urine poor idea for any config. Why was it necessary???
In addition it is not clear if you segmented that computer from accessing any Router Resources (input chain) or any other LAN devices (filter firewall).
Without seeing the whole config, it would just be more speculation which is teat useless.
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
darkuek
Re: Hacked recently
Sat Jun 15, 2019 2:31 pm
darkuek
Re: Hacked recently
Sat Jun 15, 2019 2:34 pm
I didnt dowload a clean copy but i closed trhe ports he cant log in i guess
Pea
Re: Hacked recently
Sat Jun 15, 2019 2:58 pm
Why do you think someone hacked in?
Your log shows only failed logins due to your poor firewall. You should rethink your firewall and running services.
krafg
Re: Hacked recently
Sat Jun 15, 2019 7:56 pm
To not get anymore these logs, go to IP -> Services and limit the access to local network or disable that you don't need.
Regards.
Users browsing this forum: No registered users and 14 guests
