CHSDE
RB2011 WAN interface not reaching full speed
Tue Jun 18, 2019 10:34 pm
Hi at all,
hoping that this is the correct forum for asking my question.
I've just upgraded my Internet connection from 50/5 MBit/s to 300/10 MBit/s.
My 2011 is connected to an AVM Fritzbox on ETH-5, LAN on ETH-1 both Gigabit-Ports.
The AVM Fritzbox as Gateway (cable internet) is showing 300/10 MBit/s reaching it.
But every speed test returning only 150 - 180 MBit. whilst upload rate is constant by 10 MBit/s
I looked around the forum and found some tipps, disabling LCD, set Queues to "ethernet-default" or check if Fast Track is activated.
But nothing helped yet.
Do you have any further ideas or may I show you my config somehow and you can help me investigate?
When I run speedtest I'm watching the green CPU-Box left from the padlock in top right corner of Winbox and it's very low which seems fine in my
opinion.
I would apreciate any help.
Thanks, Patrick
supplemental: my firmware is 6.44
CZFan
Re: RB2011 WAN interface not reaching full speed
Wed Jun 19, 2019 2:15 am
Start by upgrading to 6.44.3, then post results of "export hide-sensitive" here (between source code bracket so, see menu bot tons above)
MTCNA, MTCTCE, MTCRE & MTCINE
CHSDE
Thu Jun 20, 2019 1:33 pm
Hi, please excuse my late answer.
I was not informed about your post via mail notice.
I've done the upgrade with no success in speed behavior.
Please find my export down below.
set default-screen=stat-slideshow time-interval=hour
/lcd interface
set sfp1 disabled=yes
set ether2 disabled=yes
set ether3 disabled=yes
set ether4-Arlo disabled=yes
set ether6 disabled=yes
set ether7 disabled=yes
set ether8-HueBridge disabled=yes
set ether9-GWY-433 disabled=yes
set ether10 disabled=yes
/ppp secret
add name=Pxxxxxx profile=pptp-vpn service=pptp
add name=Sxxxxxx profile=pptp-vpn service=pptp
add name=Pxxxxxx profile=ovpn service=ovpn
add name=Sxxxxxx profile=ovpn service=ovpn
/system clock
/system identity
set name=Pwall
/system lcd
set contrast=0 enabled=no port=parallel type=24x4
/system lcd page
set time disabled=yes display-time=5s
set resources disabled=yes display-time=5s
set uptime disabled=yes display-time=5s
set packets disabled=yes display-time=5s
set bits disabled=yes display-time=5s
set version disabled=yes display-time=5s
set identity disabled=yes display-time=5s
set bridge1 disabled=yes display-time=5s
set WLAN disabled=yes display-time=5s
set sfp1 disabled=yes display-time=5s
set eth01-LAN disabled=yes display-time=5s
set ether2 disabled=yes display-time=5s
set ether3 disabled=yes display-time=5s
set ether4-Arlo disabled=yes display-time=5s
set eth05-WAN disabled=yes display-time=5s
set ether6 disabled=yes display-time=5s
set ether7 disabled=yes display-time=5s
set ether8-HueBridge disabled=yes display-time=5s
set ether9-GWY-433 disabled=yes display-time=5s
set ether10 disabled=yes display-time=5s
/system logging
add action=Firewall topics=firewall
add action=vpn topics=ipsec
add action=vpn topics=pptp
add action=email topics=critical
add action=email topics=error
add action=email topics=warning
add action=vpn topics=ovpn
add action=email topics=system,error,critical
/system script
add dont-require-permissions=no name=WOL_on_VPN owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive source="tool wol interface=bridge1 mac=BC:5F:F4:EF:FD:77"
/tool e-mail
set address=smtp.xxxxx.de from=axxxxx@xxxxx.net start-tls=yes user=axxxxxx@xxxxx.net
/tool graphing interface
add interface=eth05-WAN
/tool romon port
add
/tool user-manager database
set db-path=user-manager
[admin@Pwall] >
Greets Patrick
CZFan
Fri Jun 21, 2019 12:45 am
That does not look like the full export and without seeing firewall filter and mangle rules, it makes it difficult to make suggestions.
Read up on fasttrack, enable it and test again
CHSDE
Fri Jun 21, 2019 4:51 pm
Hi CZFan,
find my Firewall and NAT-config below:
/ip firewall address-list
add address=192.168.127.150-192.168.127.152 list="XBOX Live"
add action=fasttrack-connection chain=forward connection-state=established,related
add action=accept chain=forward comment="accept established and related connections" connection-state=established,related log=yes
add action=accept chain=input comment=Ping log=yes protocol=icmp
add action=accept chain=input comment=FTP disabled=yes dst-port=21 in-interface=ether10 protocol=tcp
add action=log chain=input disabled=yes dst-port=21 in-interface=ether10 protocol=tcp
add action=accept chain=forward disabled=yes dst-address-list=Xbox dst-port=53,88,500,3074,3544,4500 in-interface=ether10 protocol=udp
add action=accept chain=forward disabled=yes dst-address-list=Xbox dst-port=53,80,3074 in-interface=ether10 protocol=tcp
add action=accept chain=input comment=Established connection-state=established
add action=accept chain=input comment=Related connection-state=related
add action=accept chain=input comment=OpenVPN dst-port=443 protocol=tcp
add action=accept chain=input comment="OpenVPN Ip-Pool Zugriff auf Gateway f\FCr DNS Aufl\F6sungen " dst-address=192.168.127.254 src-address=10.0.0.0/24
add action=log chain=input dst-port=443 log=yes log-prefix=OVPN protocol=tcp
add action=accept chain=input dst-address=192.168.127.254 log=yes log-prefix=ovpn protocol=tcp src-address=10.8.0.0/24
add action=accept chain=input comment=pptp-vpn disabled=yes dst-port=1723 protocol=tcp
add action=accept chain=input disabled=yes protocol=gre
add action=log chain=input dst-port=1723 protocol=tcp
add action=log chain=input protocol=gre
add action=accept chain=input comment="Zugang zum Router via VPN (TCP)" dst-address=192.168.127.254 protocol=tcp src-address=192.168.120.0/24
add action=accept chain=input comment="Zugang zum Router via VPN (UDP)" dst-address=192.168.127.254 protocol=udp src-address=192.168.120.0/24
add action=accept chain=input comment="Internes LAN (bridge1) darf auf den Router zugreifen" in-interface=bridge1
add action=log chain=input comment="Verbotenes Droppen"
add action=drop chain=input comment="Drop (Ports nach aussen schlie\DFen)"
add action=accept chain=forward comment="Beispiel zum Freigeben bestimmter Protokolle" disabled=yes dst-address=!192.168.127.0/24 dst-port=80,443 in-interface=bridge1 protocol=tcp
add action=drop chain=forward comment="Droppe alles, was nicht explizit freigegeben ist." disabled=yes
add action=drop chain=input disabled=yes dst-port=8080 in-interface=eth05-WAN protocol=tcp
add action=masquerade chain=srcnat out-interface=eth05-WAN
add action=dst-nat chain=dstnat disabled=yes dst-port=53,88,500,3074,3544,4500 in-interface=ether10 log=yes log-prefix=XBOX_UDP protocol=udp to-addresses=192.168.127.150-192.168.127.152
add action=dst-nat chain=dstnat disabled=yes dst-port=53,80,3074 in-interface=ether10 log=yes log-prefix=XBOX_TCP protocol=tcp to-addresses=192.168.127.150-192.168.127.152
add action=dst-nat chain=dstnat disabled=yes dst-address=[##myStaticIp##] dst-address-list="XBOX Live" dst-port=53,88,500,3074,3544,4500 protocol=udp to-ports=3074
add action=dst-nat chain=dstnat dst-address=[##myStaticIp##] dst-port=3074 protocol=udp to-addresses=192.168.127.150 to-ports=3074
add action=redirect chain=dstnat disabled=yes dst-port=80 protocol=tcp to-ports=8080
sebastia
Sat Jun 22, 2019 2:27 pm
Hi
Hint: next time export config with "/export hide-sensitive compact"
When I remove all the "disabled=yes", not much is left regarding forwarding traffic:
* single masq
* single dst-nat
* fasttrack / accept established / related
What is not there:
* routing: is fritz doing natting or bridging? If so are doing double natting then?
* interfaces / addresses used
* are you testing over vpn ?
* do you test with single or multi streams? See https://www.speedtest.net, at the bottom: Connections: Multi <> Single
* to properly monitor cpu usage, use /tool profile, the visual "icon" is insufficiently updated
CZFan
Sat Jun 22, 2019 10:11 pm
Hi
i am sure "export" defaults to compact?
CHSDE
Sat Jun 29, 2019 11:36 pm
Hi, please excuse my late answer, I was on holidays ;-)
ok, find my answers within your quote.
What is not there:
--> It's natting. Bridging is disabled by providers branding.
--> I don't know exactly what you mean.
* are you testing over vpn?
--> No.
--> the speedtest get's in multimode about 180 Mbit in singlemode about 170 Mbit.
--> While in "idlestate " cpu0 is about 3.0 - 4.0. While in speedtest max usage was at 30.
I've ran /export hide-sensitive compact and got something strange. Please look at this:
add arp=proxy-arp name=bridge1
set [ find default-name=ether1 ] arp=proxy-arp name=eth01-LAN speed=100Mbps
set [ find default-name=ether5 ] name=eth05-WAN speed=100Mbps
set [ find default-name=ether2 ] speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] name=ether4-Arlo speed=100Mbps
set [ find default-name=ether6 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether7 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether8 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=ether8-HueBridge
set [ find default-name=ether9 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=ether9-GWY-433
set [ find default-name=ether10 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
Why are my eth01-LAN and eth05-WAN running at 100 Mbps? They're connected to the Gigabit-Ports marked on the front-side of the RB2011.
My whole internal cabeling is managed by 1Gbit switches (Netgear GS 108)
And even when they're at 100 Mbps. How is can I get an internetspeed result of around 180 Mbps?
I'm really confused.
Patrick
...an additional annoation: When I look at Winbox' Interface/eth01-LAN or eth05-WAN/Status via the GUI both tell me a Rate of 1Gbps by Ful Duplex.
mkx
Sun Jun 30, 2019 12:08 am
Command /export [compact] only shows settings that are different than default.
Ports in /interface ethernet have many settings, speed= is one of them. Setting of 100M used to be default in ROS prior to 6.42 (IIRC) and if your setup originates from earlier ROS, this value did not change with upgrade hence it appeared in export after upgrade to a more recent ROS.
However, there's a setting auto-negotiation with default value of yes which makes port to ignore most of other settings, including speed. Setting of advertise is one of observed settings though.
Actual running port speed is displayed by command /interface ethernet monitor <port name> once .
BR,
Metod
sebastia
Mon Jul 01, 2019 9:01 pm
In your first post you mentioned
. Have you tried doring a speedtest directly attached to the fritz? What were the results?
CHSDE
Tue Jul 02, 2019 2:00 am
Hi at all.
The problem is on providers side.
Tested now directly at the Fritzbox. Also only about 180 Mbps. Contacted my provider who confirmed the issue on his side, too.
I think we may keep this thread as solved.
Best regards and thanks for all the hints with those terminal commands.
Patrick
Users browsing this forum: MSN [Bot] and 34 guests
