xiaotuzi
Mikrotik App - Connection refused
Sat Jun 22, 2019 7:56 pm
I just godt a CRS1009-7 and got it up and running, which was surprisingly easy considering everything I heard about how difficult Mikrotik devices could be to set up.
Now I installed the App on my iPhone and wanted to connect but i keep getting connection refused even though I am on wifi and the api is enabled in RouterOS. I doublechecked the router username and password.
Any ideas as to what can be wrong. My laptop which is on the same subnet/wifi can easily access via winbox.
normis
Re: Mikrotik App - Connection refused
Wed Jun 26, 2019 11:13 am
Is Winbox allowed on that interface? the App uses winbox, not API
anav
Wed Jun 26, 2019 4:21 pm
Assuming you are trying to connect to the router from within your wifi network at home and not externally like at the coffee shop???
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
Users browsing this forum: Google [Bot] and 8 guests
