winnerke
Scripting distance of routes
Mon Jun 24, 2019 6:11 pm
I would like to get the distance of a route for scripting purpose.
something like :
if([/ip route get "distance of a route"] = 5 ) do={
:log error "distance is 5";
but i can't get any command that provides me a distance of a route.
winnerke
Re: Scripting distance of routes
Mon Jul 08, 2019 3:12 pm
BUMP
andriys
Mon Jul 08, 2019 3:25 pm
Try this:
:if ([/ip route get [find <your_search_criteria_goes_here>] distance] = 5) do={
winnerke
Tue Jul 09, 2019 5:40 pm
Try this:
This does not work.
Tried the following :
:if ([/ip route get [find gateway=x.x.x.x] distance] = 3) do={
    :log error "test2"
It keeps logging test2, no matther what distance i put in the if/else statement.
2frogs
Long time Member
Long time Member
Tue Jul 09, 2019 7:45 pm
Spacing maybe!?!? This works for me:
:if ([/ip route [find gateway=x.x.x.x] distance]=2) do={:log error “True”}
winnerke
Tue Jul 09, 2019 11:10 pm
This also does not work for me.
2frogs
Long time Member
Long time Member
Re: Scripting distance of routes  [SOLVED]
Wed Jul 10, 2019 3:05 am
Is x.x.x.x a unique ID or do you have multiple with gateway=x.x.x.x?
Copy and paste the following in Terminal:
/ip route add dst-address=1.2.3.4/32 gateway=1.2.3.4 distance=5;
:if ([/ip route get [find gateway=1.2.3.4] distance]=5) do={:put "True"} else={:put "False"};
##Should have output of "True" since distance is 5;
/ip route set [find gateway=1.2.3.4] distance=6;
##Should have output of "False" since distance is 6;
:if ([/ip route get [find gateway=1.2.3.4] distance]=6) do={:put "True"} else={:put "False"};
##Should have output of True since IF/ELSE and distance is 6;
Should look like this!
winnerke
Wed Jul 10, 2019 6:03 pm
Indeed this works on my main Mikrotik, but not on the other one.
When running this , i get "invalid internal item number"
winnerke
Wed Jul 10, 2019 6:31 pm
This worked for me :
:if ([/ip route get [:pick [find gateway=x.x.x.x] 0] distance]=1) do={:put "True"} else={:put "False"}
this because i had multiple routes with the same gateway as you guys said.
Thanks !
Users browsing this forum: No registered users and 14 guests
