mahumada
Simulation two WAN with one ISP
Wed Jun 26, 2019 5:06 pm
How can I do a simulation of two WANs with different GWs if I have a single ISP in order to be able to practice load balancing?
Thank you.
2frogs
Long time Member
Long time Member
Re: Simulation two WAN with one ISP
Thu Jun 27, 2019 7:25 am
Use Virtual Machine software (I use VirtualBox) to setup 2 Virtual CHR's. You need 2 virtual ethernet interfaces for each. They need minimal setup:
##Gateway1
add address=192.168.100.1/24 interface=ether2 network=192.168.100.0
/ip dhcp-client
add disabled=no interface=ether1
##Gateway2
add address=192.168.200.1/24 interface=ether2 network=192.168.200.0
/ip dhcp-client
And now on your Real Router add:
add address=192.168.100.2/24 interface=bridge1 network=192.168.100.0
add address=192.168.200.2/24 interface=bridge1 network=192.168.200.0
Now you can use 192.168.100.1 & 192.168.200.1 as your gateways in the tutorials. Example:
add check-gateway=ping distance=1 gateway=192.168.100.1 routing-mark=GW1
add check-gateway=ping distance=1 gateway=192.168.200.1 routing-mark=GW2
ingdaka
Fri Jun 28, 2019 10:32 pm
If you have 2 different gateways is one situation, if you have only 1 gateway you need L2 loadbalancing with is via portchannel
Ilir Daka
Electronic & Network Engineer
E-mail: ilirdaka@live.com
Mob: +355692982151
WhatsApp: +355692982151
Mikrotik Official Consultant
CCNA | Fortinet NSE3 | MTCRE | MTCSE | MTCWE | RIPE NCC Certified Professional
stoser
Mon Jul 01, 2019 4:59 am
If all you want to do is simulate and view the traffic going out two different interfaces, you can probably use the
IP%interface
notation for the gateway values in the routing rules. So if your ISP LAN gateway is 192.168.0.1, and your WAN1 interface name is "ether1", and your WAN2 interface name is "ether2" use
192.168.0.1%ether1 for the gateway value in your routing rule for WAN1, with the corresponding routing mark and
192.168.0.1%ether2 for the gateway value in your routing rule for WAN2, with the corresponding routing mark
samwoodblack
Fri Jul 12, 2019 4:49 pm
I think that idea with virual machine is the best.
My latest comparison. Writing articles about technology and gadgets.
Users browsing this forum: ChristopherFS, gfhahsvhj, RobSav and 45 guests
