pedroSwan
Port Forwarding (AND MORE) Still Not Working
Mon Jul 01, 2019 12:56 am
I have tried everything I possibly can to get my Port Forwarding working.
I have a VDSL2 modem sat ahead of my Mikrotik Router. Router is at 192.168.1.1. WAN is static address at 82.xxx.xxx.xxx (we'll call it 82.111.111.111 for ease of explanation)
I really would like to get the Port Forwarding set up but I fear there are some issues ahead of this which need fixing.
Setup:
Netgear DM200 Modem PPPoE VDSL Connection
RB2011 UiAS-RM
Ubiquiti AC-Lite Wireless AP
What is good:
- All my devices connect well to the Mikrotik and all go out onto the internet just fine.
- Internally they can all communicate between themselves
- DHCP internally works perfectly
- Data rates are good
- WinBox wired is perfect
Not so good:
- Wireless connection to 192.168.1.1 fails on my Mac
- Port Forward to IP Camera at 192.168.1.222, TCP, Port 8081 Fails
I have used this command for the camera forward:
add chain=dstnat dst-address82.111.111.111 protocol=tcp dst-port=8081 action=dst-nat to-addresses=192.168.1.222
I used this code for the basic Firewall settings:
/ip firewall address-list
add address=0.0.0.0/8 comment="Self-Identification [RFC 3330]" list=Bogons
add address=10.0.0.0/8 comment="Private[RFC 1918] - CLASS A # Check if you nee\
 d this subnet before enable it" list=Bogons
add address=127.0.0.0/8 comment="Loopback [RFC 3330]" list=Bogons
add address=169.254.0.0/16 comment="Link Local [RFC 3330]" list=Bogons
add address=172.16.0.0/12 comment="Private[RFC 1918] - CLASS B # Check if you \
 need this subnet before enable it" list=Bogons
add address=192.0.2.0/24 comment="Reserved - IANA - TestNet1" list=Bogons
add address=192.88.99.0/24 comment="6to4 Relay Anycast [RFC 3068]" list=\
 Bogons
add address=198.18.0.0/15 comment="NIDB Testing" list=Bogons
add address=198.51.100.0/24 comment="Reserved - IANA - TestNet2" list=Bogons
add address=203.0.113.0/24 comment="Reserved - IANA - TestNet3" list=Bogons
add address=224.0.0.0/4 comment=\
 "MC, Class D, IANA # Check if you need this subnet before enable it" \
 list=Bogons
add action=accept chain=forward comment="defconf: accept established,related" \
    connection-state=invalid
add action=accept chain=input port=69 protocol=udp
add action=accept chain=forward port=69 protocol=udp
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new in-interface=ether1
add action=drop chain=forward comment="Drop to bogon list" dst-address-list=\
 Bogons
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface=ether1
But I have tried the forwarding with this rules off and on
It will be something this noob has done but I've given it a good go so calling out for some help now please
MikroTik RB2011UiAS-RM
Firmware Type: ar9344
Current Firmware: 6.45.6
MikroTik RB2011UiAS-2HnD-IN
anav
Re: Port Forwarding (AND MORE) Still Not Working  [SOLVED]
Tue Jul 02, 2019 4:23 pm
What are those for? The only ports you should be allowing to or across your router is NONE!!
(well maybe DNS to your router but only from the LAN side + admin access on the lan side to the router for router management)
Remove these rules, unless you have a clear reason???
add chain=dstnat dst-address=82.111.111.111 protocol=tcp dst-port=8081 action=dst-nat to-addresses=192.168.1.222
On the surface nothing seems wrong with this rule except I had to insert the equal side but figured that was a typo not an error in your config??
What is eth1 connected to? I am assuming this is the static WANIP from your netgear modem?
I would get rid of this rule.....
Instead at the end of your input chain (last rule) simply put
add action=drop chain=input (drop all other traffic).
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
pedroSwan
Tue Jul 02, 2019 9:05 pm
Thanks anav, really appreciate the reply.
Ether1 is connected directly to the VDSL router which is at 192.168.1.1
As for the forward to 69, that is typo and should have read 6690 for VPN. I have moved on a little now, or backwards and have gone back to a clean but probably vulnerable config.
Sorry for the double post the moderation didn't appear to have taken affect, it has now.
To save duplicate posting and threads off topic here is the link viewtopic.php?f=13&t=149847
anav
Wed Jul 03, 2019 5:23 am
What you should start fresh with is the default setup as that is safe and a good place to start.
pedroSwan
Wed Jul 03, 2019 7:22 am
Thanks, I resorted to that. Linked thread is where I’m at. Thanks
Users browsing this forum: edtjones, Majestic-12 [Bot] and 28 guests
