ElectronicEric
Cannot access Hikvision NVR remotely
Wed Jul 03, 2019 10:16 pm
I have a Hikvision NVR (NR51P6-16), 192.168.11.142. It is wired directly to MikroTik v.6.43.12, 192.168.11.1.
I have Port 8080 open for Server Access on the Hikvision NVR: Image
With the respective DST-NAT Firewall rule forwarding traffic to the NVR on the MikroTik: Image
Problem is, when I hit my Public IP externally, I get the MikroTik router page, not the Hikvision NVR.
Help is greatly appreciated!
scampbell
Trainer
Trainer
Re: Cannot access Hikvision NVR remotely
Fri Jul 05, 2019 7:44 am
Please post your dst-nat rule.
Hikvision works fine with Mikrotik, both for web and IVMS client
MTCNA, MTCWE, MTCRE, MTCTCE, MTCSE, MTCINE, Trainer
___________________
Mikrotik Distributor - New Zealand
http://www.campbell.co.nz
ingdaka
Fri Jul 05, 2019 1:57 pm
First of all NR51P6-16 is not any Hikvision Device, maybe any Chinese copy of hikvision!
Second you if port 8080 is open in nat and is available on NVR you should type Public IP:8080 in your browser not just IP, because if you type only IP will respond to port 80 which belong to router web page!
Ilir Daka
Electronic & Network Engineer
E-mail: ilirdaka@live.com
Mob: +355692982151
WhatsApp: +355692982151
Mikrotik Official Consultant
CCNA | Fortinet NSE3 | MTCRE | MTCSE
Docop
Sun Jul 07, 2019 3:46 pm
I got the same issues and my Hik cam was working when i set a port foward. Now the firewall rules are quite too hard and that don't work anymore, but i just connect via vpn and uber safer than having a openport.
inteq
Sun Jul 07, 2019 6:07 pm
Maybe because the default port is 8000 and not 8080?
Users browsing this forum: Bing [Bot] and 26 guests
