sba010
5 port switch + wlan + guest wlan using rb951
Thu Jul 04, 2019 8:27 am
I just bought this routerboard and need the following config running.
a) 5 port switch + wlan (dhcp provided from ISP router, plugging a cable on a etherX)
b) Guest wlan isolated with own dhcp, only internet access.
Current network 192.168.1.0/24
Any help will be appreciated
anav
Re: 5 port switch + wlan + guest wlan using rb951
Thu Jul 04, 2019 2:22 pm
Did you do any research before buying the routerboard of unknown type/name?
This is not a consumer off the shelf plugnplay device except for the default settings that allow it to be used out of the box but then
needs configuring beyond that.
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
sba010
Thu Jul 04, 2019 3:41 pm
Model RB951G-2HnD
I know that, I used this devices before, just can't get this config working. Are you telling me that it can't do this?
I can make the bridge with 5 ether + wlan and that works.
Then I create a VirtualAP, a DHCP and IP pool for it. But when connecting to guest SSID I have no Internet.
Need advice on the firewall and NAT rules. I think that is the problem.
anav
Thu Jul 04, 2019 7:34 pm
All that you have stated is very doable.
However one cannot guess at your current setup.
Please post your config for anal ysis.
/export hide=sensitive file=yourconfig4july
Users browsing this forum: Google [Bot] and 24 guests
