dirks
TX Sector Info - Alignment of RBwAPG-60ad
Thu Jul 04, 2019 10:08 am
coming from ubnt hardware i've started now with my first mikrotik and 60ghz experience. So everything is new to me, please be kind :)
I've replaced a short 80 meter nanobeam 5ghz link with the RBwAPG-60ad kit and asking me now how to adjust those great and powerful antennas.
How to align them to the perfect way? At the moment TX Sector Info says: right 11.4 degrees, up 3.8 degrees. So i assume there is a big tilt. Don't get me wrong, the link already works perfect with a great troughput but i want to make it as good as possible.
The link signal is stable 90 and MCS is 8. My feeling says there should be a signal of 100 with highest MCS possible. There is a free LOS.
But due to my less experience with RouterOS and 60ghz and the not really adjustable mounting of the devices i'm asking you guys what should i expect from the link?
Please give me some input how to use RouterOS to make a perfect alignment.
Is there also some better mounting available to tilt and turn the devices in a better way?
Cheers
Dirk
dirks
Re: TX Sector Info - Alignment of RBwAPG-60ad
Thu Jul 04, 2019 4:38 pm
So here i have more data now:
AP:
/interface w60g> monitor 0
connected: yes
frequency: 58320
remote-address: 04:D6:AA:A9:AD:60
tx-mcs: 8
tx-phy-rate: 2.3Gbps
signal: 90
rssi: -55
tx-sector: 27
tx-sector-info: center
distance: 88.7m
tx-packet-error-rate: 0%
Station:
connected: yes
frequency: 58320
remote-address: 04:D6:AA:A8:0E:6B
tx-mcs: 8
signal: 90
rssi: -56
tx-sector: 34
tx-sector-info: right 11.4 degrees, up 3.8 degrees
distance: 88.71m
I'm wondering that i'm in center on the AP side but tilted on the station side. If the alignment is not 100% good it can not be centered on any side.
Regards
Dirk
scampbell
Trainer
Trainer
Fri Jul 05, 2019 7:32 am
Hi Dirks,
The aerial for the WAP60AD is a 8x8 multi-sector array starting at top left 0 ending bottom right 63 (think in terms of a 8x8 grid or table) so sector 27 or 35 is roughly in the middle while sector 34 is meaning a little to the left and perhaps down a bit.
This is indicated in the client tx-sector info which indicates how you could turn the aerial to improve signal.
I use the Mikrotik QMP Quickmount Pro and mount the WAP60AD onto the optional round bracket with a pair of cable ties and use this to better align the aerial if required.
But Mikrotik tell me the idea of the aerial array is to imagine a pair of eyes looking left or right, up or down and they "auto-align". They are designed to work this way and not being perfectly aligned is acceptable. For me you do the best to align the devices then trust the Mikrotik engineers :-)
My experience with these has been very good (up to 200m) - just make sure you are running the latest Longterm Support version of RoS to get the best out of them.
Hope this was helpful..... :-)
MTCNA, MTCWE, MTCRE, MTCTCE, MTCSE, MTCINE, Trainer
___________________
Mikrotik Distributor - New Zealand
http://www.campbell.co.nz
dirks
Fri Jul 05, 2019 8:48 am
Hi scampell,
yes you helped me a lot of understanding the devices! Thanks a lot! So i'm not that misaligned as i thought, which is great.
I also will give a try to the QMP, it is cheap and looks good. Didn't know anything about the auto-align functionality but seems to work good. I'm slightly tilted and the devices already have the full power and throughput.
Best regards
Dirk
Users browsing this forum: Google [Bot] and 17 guests
