EvgeniyOsipov
2 ISP + L2TP/IPsec
Sat Jul 27, 2019 8:54 pm
On mikrotik I have two ISP (dhcp client (main) and ppoe(reserve)) and configured l2tp/ipsec server.
Everything works good, except one thing - when I manually changing to second ISP (reserved channel) for one PC through mangle rule, then can't reach (ping, rdp, etc) this PC from VPN client (outside LAN). But can reach another PCs as usual.
How orginize routes or mangle rules for VPN clients for reaching LAN PCs (ping, rdp, vnc, like in regular LAN) despite the changes of ISP?
Thank you for any advice.
cdiedrich
Forum Veteran
Forum Veteran
Re: 2 ISP + L2TP/IPsec
Wed Jul 31, 2019 2:00 pm
I guess you add routing marks for this PC, correct?
You'll need to add a route to this PC with its new routing mark to work.
like:
/ip route add dst-address=192.168.88.22 gateway=bridge routing-mark=myWan2-mark
Edit:
And probably (if even not more likely) a route to the vpn client with that routing mark. This can be accomplished with static addresses in the ppp client definition and a static l2tp server binding.
-Chris
Christopher Diedrich
MTCNA, MTCUME, MTCWE
Basel, Switzerland
Bremen, Germany
There are 10 types of people: Those who understand binary and those who don't.
There are two types of people: Those who can extrapolate from incomplete data
EvgeniyOsipov
Fri Aug 02, 2019 11:05 am
like:
Edit:
-Chris
Hello, thank you for answer!
Please see https://1drv.ms/u/s!AkiJ7dh7F4kUhIlxBvFCFnYktEJujg, I can't make it work through Routes.
EvgeniyOsipov
Mon Sep 16, 2019 7:12 pm
Anyone?
Users browsing this forum: smidliboy, UnknownUsername and 25 guests
