kitamanis
Mikrotik OSPF Lacp MultiAreas
Mon Jul 29, 2019 9:25 am
Iam strugling to make this scheme work, which commands should I use? How to make Areas ping each other? and how to run lacp protocol, now I am using only one wire between routers.
kitamanis
Re: Mikrotik OSPF Lacp MultiAreas
Tue Jul 30, 2019 9:41 am
leoservices
Trainer
Trainer
Thu Aug 01, 2019 9:16 pm
You can use all 3 routers in the same area. In OSPF you will make a simple balance between these links.
https://wiki.mikrotik.com/wiki/Manual:OSPF-examples
I try to help !
Leonardo Vieira
https://youtube.com/contractti
Like Facebook.com/contractti
kitamanis
Fri Aug 02, 2019 10:32 am
My task is to connect routers from diffrent areas
kitamanis
Fri Aug 02, 2019 10:42 am
I have 3 routers connnected by OSPF protocol, 1, 2 ir 3. Between 1 and 2 there is Area0 backbone, between 1 and 2 there is Area2, and between 2 and 3 there is Area1. Iam pinging between 1 and 2 and its possible, but I cant ping between 1 and 2 or between 2 and 3, is it good? Or should I get ping between 1 and 2 or 2 and 3. Thanks for the answers..
--kitamanis
Users browsing this forum: No registered users and 23 guests
