CVXDEV
Setup of 2x crs328-24p-4s+rm: Questions
Tue Jul 30, 2019 12:50 pm
Dear all,
I have some questions related to a desired set-up and some issues which don't work - any input/feedback is appreciated, thanks!
Set-up:
  • Router "0" (ISP) --> Router #1 running RouterOS (CRS328) --> Router #2(CRS328) running RouterOS
    Router 0 to #1: RJ45 to ETH1
    R#1 to R#2: Fiber via SFP1 to SFP1
Scenario:
I would like to have separate networks for the ISP Router#0 and the both MikroTik Router#1&#2
  • R#0: 192.168.178.xxx
    R#1&2: 192.168.88.xxx
Connection of R#0 to R#1 is fine, R#1 gets all necessary data:
R#1: Router Mode / Port: ETH1 / Automatic Address acquisition
Internet: IP: 192.168.178.59 / 255.255.255.0 / Gateway: 192.168.178.1
LAN: 192.168.88.11 / 255.255.255.0 / DHCP- Server: ON / DHCP-Range: 192.168.88.21-199 / NAT: ON
Now i would like to connect Router #2 - either as Router or Bridge (what would you suggest?)
A.) as Router
R#2: Router Mode / Port: SFP1 / Automatic Address acquisition
Internet: IP: 192.168.88.192 / 255.255.255.0 / Gateway: 192.168.88.11
LAN: 192.168.88.12 / 255.255.255.0 / DHCP- Server: ON / DHCP-Range: 192.168.88.205-239 / NAT: ON
Problems:
- when connected via RJ45 to R#2 with a Computer, I can't access the Internet, e.g. google.com (ping of 8.8.8.8 works though from the Router#2 console and connected PC)?
- what setting am I missing?
B.) as Bridge
  • Automatic Address acquisition / Address Source: Any
--> in this case the Router can't get an IP (0.0.0.0) and won't do anything --> have to connect via WINBOX and reset or manual configure the switch.
  • Manual:
Static / 192.168.88.12 / 255.255.255.0 / Gateway: 192.168.88.11 / DNS: 192.168.178.1
--> Internet via a connected PC to R#2 works in static Bridge mode, but weirdly I get IP-addresses assigned which are out of R#1 range (i got 192.168.88.207)
Summary:
  • - ideally i would let the both Routers run as Routers & DHCP-Servers - is that possible? what am I missing for case A.)?
  • - if in bridge mode, why do i get these out of range IP-addresses?
Thanks in advance for any help/feedback.
Cheers
Users browsing this forum: No registered users and 20 guests
