vanblunt
No internet on LAN - hex rb750gr3 with E3372
Tue Jul 30, 2019 10:47 pm
Hi all.I have issue which seems to be simple but I cannot figure it out. I received HEX RB750GR3 from my friend. I connected Huawei E3372 Hilink to it and factory defaulted Hex. Now HEX has internet access (I can ping google.com from terminal) but devices on LAN don't. My laptop is connected to LAN and it gets IP address, I can access HEX but internet doesn't work. I made a test and connected internet with cable to first ethernet port - in this scenario internet on LAN devices works. But with LTE it doesn't. What am I doing wrong? I have the latest firmware (6.44.5). I tried finding answer to this issue online but no one seems to have this problem. Anyone knows what needs to be done?
anav
Re: No internet on LAN - hex rb750gr3 with E3372
Wed Jul 31, 2019 5:43 pm
Ahh so you realized your friend is really your enemy LOL.
He gave you a gift that is giving you headaches.
Mikrotik is not a plugNplay device for the IT illiterate crowd but does take some work.
Stick through the initial tough beginning and you will enjoy working in RouterOS.................
Suggest posting your config for viewing to determine what is going on.
/export hide-sensitive file=yourconfig31july
(ensure you remove your actual WANIP address)
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
vanblunt
Wed Jul 31, 2019 7:37 pm
Hahaha! Yes, it turns out my friend is not really my friend anymore ;)
Maybe Mikrotik is not plug&play but if I factory default it and then connect internet to 1st port (labeled Internet) then everything works fine. But if I disconnect cable from Internet port and try the same with USB modem plugged in then internet doesn't work on LAN.
Anyways, my Hex RG750GR3 config is absolutely default - as I said before, I plugged Huawei E3372 153s USB modem to it and factory defaulted it. And internet works - I can ping out from terminal (for example google.com). It just doesn't work on devices connected to LAN ports.
Here's the config (my WAN IP is not public so no need to hide anything. Plus I don't see it in config anyway):
# jul/31/2019 18:21:12 by RouterOS 6.44.5
# software id = 3TTR-Z1L9
# model = RouterBOARD 750G r3
# serial number = 6F3807C9C785
/interface lte
set [ find ] mac-address=0C:5B:8F:27:9A:64 name=lte1
add admin-mac=64:D1:54:91:7D:BA auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
ether1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/system clock
set time-zone-name=Europe/Warsaw
/tool mac-server
/tool mac-server mac-winbox
Any help would be greatly appreciated! Thanks in advance.
anav
Wed Jul 31, 2019 9:48 pm
None of your routing information/config is there??
vanblunt
Wed Jul 31, 2019 10:19 pm
Nope. That's all output I get from the command you provided.
mkx
Wed Jul 31, 2019 10:20 pm
Probably because all of it is dynamic. /ip route print and /ip address print would reveal lots of things. Before posting output of these commands do obfuscate public IP addresses ... but do it consistently so that it will be obvious what belongs together.
My wild guess: in order to get internet over LTE working for LAN hosts, the LTE interface (as seen by ROS) will have to be added to members of WAN interface list (so that default SRC-NAT rule will do its magic).
BR,
Metod
vanblunt
Wed Jul 31, 2019 11:16 pm
There you go:
[admin@MikroTik] > /ip route print
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADS 0.0.0.0/0 192.168.8.1 2
1 ADC 192.168.8.0/24 192.168.8.100 lte1 0
2 ADC 192.168.88.0/24 192.168.88.1 bridge 0
[admin@MikroTik] > /ip address print
# ADDRESS NETWORK INTERFACE
0 ;;; defconf
192.168.88.1/24 192.168.88.0 bridge
1 D 192.168.8.100/24 192.168.8.0 lte1
Let me know if you need any other info. What's the command to add LTE interface to members of WAN interface list?
CZFan
Thu Aug 01, 2019 12:07 am
Besides what @mkx said, I don't see where the client devices get DNS config from.
Add DNS server IPs under DHCP server networks
MTCNA, MTCTCE, MTCRE & MTCINE
vanblunt
Thu Aug 01, 2019 12:21 am
Thanks for advice but I don't think that's what the issue is. If I ping google.com from LAN device, the address gets resolved. But I don't get any response.
anav
Thu Aug 01, 2019 3:17 am
Such confidence!
Well mkx and CZFan know far more than most here, thus your level of knowledge must be beyond me then so I am not able to provide any further assistance.....
mkx
Thu Aug 01, 2019 7:02 am
So did you try to add lte1 interface to WAN interface list? Did it do the trick or not?
BR,
Metod
vanblunt
Thu Aug 01, 2019 12:09 pm
I did. And it works now! It took some time for it to work as the change required reboot which I wasn't aware of... Thank you so much for the advice!
@anv:
As I stated before, my level of Mikrotik knowledge is none - hence I asked for help here. But I have some network knowledge so when I see address being resolved from LAN client then I can be 100% sure the issue is not with DNS. I greatly appreciate your help anyway. Thanks for taking time to look into this.
anav
Thu Aug 01, 2019 7:55 pm
Glad it worked out for you!
Users browsing this forum: YaCy [Bot] and 33 guests
