danjde
Disabling o removing DNS Dynamic Servers
Wed Jul 31, 2019 11:38 am
Hi Friends,
I'm using a Mikrotik SXT LTE kit (product code RBSXTR&R11e-LTE).
I've added DNS primary and secondary both by OpenDns, now I would like to remove the provider Dynamic Server.
Could you suggest the right way?
I've search on the documentation with no luck :-?
Many thanks!
Davide
erlinden
Re: Disabling o removing DNS Dynamic Servers
Wed Jul 31, 2019 11:43 am
/ip dhcp-client set use-peer-dns=no
(client is 0)
danjde
Wed Jul 31, 2019 12:00 pm
Hi erlinden and thanks for your reply!
I've try:
1) /ip dhcp-client set use-peer-dns=no
2) numbers: 0
Script Error: action cancelled
"0" to the question "numbers" was that what you wanted to say?
Thanks again!
Davide
sebastia
Wed Jul 31, 2019 12:04 pm
try this
/ip dhcp-client set use-peer-dns=no [find]
danjde
Wed Jul 31, 2019 12:31 pm
Well, this second command did not give me errors, but how can I check if Dynamic Server has been removed?
Looking into webfig -> IP -> DNS It is still present:
Dynamic Servers 83.158.240.241
Thanks Again!
Davide
erlinden
Wed Jul 31, 2019 1:28 pm
Can you show /ip dns print?
WebFig might have an caching thingie...
danjde
Wed Jul 31, 2019 1:32 pm
/ip dns print
                      servers: 218.67.222.222,208.67.220.220
              dynamic-servers: 83.158.240.241
        allow-remote-requests: yes
          max-udp-packet-size: 4096
         query-server-timeout: 2s
          query-total-timeout: 10s
       max-concurrent-queries: 100
  max-concurrent-tcp-sessions: 20
                   cache-size: 2048KiB
                cache-max-ttl: 1w
                   cache-used: 79KiB
Thanks again!
Davide
msatter
Wed Jul 31, 2019 1:48 pm
I can't also not shed those and made a feature request for that.
viewtopic.php?f=1&t=45934&p=741888#p741888
One RB4011 and a RB760iGS (hEX S) in series. 4011 Does PPPoE/IKEv2-500/600 Mb/s.
Running:
RouterOS 6.47rcX / Winbox 3.24 / MikroTik APP 1.3.12
NordVPN viewtopic.php?f=2&t=158439&p=781009 for multiple connections.
erlinden
Wed Jul 31, 2019 1:58 pm
That's strange, especially as this seems to be a (your?) public IP address...
Your provider uses ns0.proxad.net and ns1.proxad.net (212.27.32.2 and 212.27.32.130).
Can you post a /export hide-sensitive please?
What version are you running?
danjde
Wed Jul 31, 2019 3:03 pm
# jul/31/2019 13:59:43 by RouterOS 6.42.10
# software id = J73U-WMIG
# model = RBSXTR
# serial number = A1870A9D55E4
/interface lte
set [ find ] mac-address=AC:FF:FF:00:00:00 mtu=1500 name=lte1 network-mode=3g,lte
add admin-mac=74:4D:28:23:BD:7F auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] apn=iliad
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add comment=defconf interface=lte1 list=WAN
add address=192.168.88.1/24 comment=defconf interface=ether1 network=192.168.88.0
set allow-remote-requests=yes servers=218.67.222.222,208.67.220.220
/ip dns static
add address=192.168.88.1 name=router.lan
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface-list=!LAN
/ip service
set ssh port=*****
/system clock
set time-zone-name=Europe/Paris
/system routerboard settings
set silent-boot=no
/tool mac-server
/tool mac-server mac-winbox
Version v6.42.10 (long-term)
Thanks again!
Davide
CZFan
Wed Jul 31, 2019 11:38 pm
Try version 6.44.5 long term
MTCNA, MTCTCE, MTCRE & MTCINE
danjde
Thu Aug 01, 2019 11:14 am
..excuse me for the silly question, but how I could upgrade to 6.44.5 long term? Could you give me a documentation link page?
And eventually do I run the risk of turning my SXT LTE kit into a paperweight?..
Thanks again!
Davide
msatter
Thu Aug 01, 2019 1:02 pm
I am on a Beta and that one also does not allow to remove the dynamic servers.
Running:
erlinden
Thu Aug 01, 2019 1:20 pm
There is a WiKi page on how to upgrade a RB:
https://wiki.mikrotik.com/wiki/Manual:U ... g_RouterOS
I know that 6.45.2 (current stable) works flawless...not sure why the beta isn't.
Upgrading is not without risks. Make sure you have a backup before performing the upgrade.
danjde
Thu Aug 01, 2019 2:03 pm
Well, thanks!
Could you suggest the right way for a backup and eventually the right way for revert to the saved backup?
Thanks again!
Davide
danjde
Fri Aug 02, 2019 3:09 pm
From Mikrotik Support:
Disable dhcp-clients "user-peer-dns" function:
/ip dhcp-client set 0 use-peer-dns=no
Davide
danjde
Wed Aug 07, 2019 8:35 pm
(again) from MIkrotik Support:
/interface lte apn set use-peer-dns=no
and then digit:
0
This one works fine!
/ip dns print
              dynamic-servers:
                   cache-size: 2048KiB
                cache-max-ttl: 1w
                   cache-used: 35KiB
Davide
Users browsing this forum: Baidu [Spider], freemannnn, sutrus and 40 guests
